CPU или конечный автомат, что лучше |
May 15 2012, 11:59
Пользователь №: 27 512
Вот хорошая дискусия по поводу >1024 инструкций http://forums.xilinx.com/t5/PicoBlaze/Pico...ctions/td-p/710only on Xilinx devices наверное потому, что kcpsm3.vhd написан на встроенных компонентах типа LUT4, MUXCY а не по злоби?
May 15 2012, 12:12
Пользователь №: 70 424
Цитата(anatolich @ May 15 2012, 14:59)  only on Xilinx devices наверное потому, что kcpsm3.vhd написан на встроенных компонентах типа LUT4, MUXCY а не по злоби? Таки по жлоби.... Вот на Xilinx форуме нашёл ( http://forums.xilinx.com/xlnx/board/crawl_...;message.id=665): Цитата As Barrie points out, the picoBlaze IP is not well suited to a standard cell implementation (it is intentionally intended to be an optimal mcro-controller in the Xilinx architecture), and it is also a prohibited use to implement it in anything other than Xilinx components under the quoted agreement.
Of course, everything is negotiable (for the right $), so one could obtain a license to use it elsewhere, but I am unaware of anyone negociating, paying for, and obtaining one. If you plan on going to an ASIC, you would probably be better off to choose another controller.
Good luck, Austin Lesea Principal Engineer Xilinx San Jose Ну и цитата с "Xilinx Reference Design License" Цитата Access to the Designs is provided only to purchasers of Xilinx programmable logic devices or Xilinx HardWire™ devices for the purposes set forth herein.
anatolich CPU или конечный автомат May 5 2012, 09:53 iosifk Цитата(anatolich @ May 5 2012, 13:53) ...... May 5 2012, 11:59 des00 picoblaze - time to study is less that a day May 5 2012, 12:13 Джеймс Цитата(anatolich @ May 5 2012, 13:53) нав... May 5 2012, 12:29 alexPec Цитата(Джеймс @ May 5 2012, 16:29) Из пуш... May 5 2012, 13:11 Bad0512 Цитата(anatolich @ May 5 2012, 16:53) Я п... May 5 2012, 14:19 iosifk Цитата(Bad0512 @ May 5 2012, 18:19) А в ч... May 5 2012, 17:39  Bad0512 Цитата(iosifk @ May 6 2012, 00:39) Как я ... May 6 2012, 03:06   iosifk Цитата(Bad0512 @ May 6 2012, 07:06) А вот... May 6 2012, 13:40    des00 Цитата(iosifk @ May 6 2012, 08:40) Вот то... May 6 2012, 16:24    Bad0512 Цитата(iosifk @ May 6 2012, 20:40) Смотри... May 7 2012, 17:52     iosifk Цитата(Bad0512 @ May 7 2012, 21:52) ...В ... May 9 2012, 06:58      Bad0512 Цитата(iosifk @ May 9 2012, 13:58) Я для ... May 10 2012, 16:37 Mad_max Выскажу свое мнение.
Резких высказываний на форум... May 6 2012, 18:26 SFx если UART на ~4 команд до FSM. Fmax = Highest
ес... May 6 2012, 20:38 anatolich Цитата(SFx @ May 7 2012, 00:38) если UART... May 15 2012, 07:45  Barktail Цитата(anatolich @ May 15 2012, 11:45) Мн... May 15 2012, 07:54 Leka Вообще-то полезно решать иногда несложные задачи ... May 10 2012, 06:27 anatolich Уважаемые коллеги,
извините что не мог на праздник... May 10 2012, 09:08 anatolich Хорошо!
А если не влезает, то наверное я долже... May 15 2012, 08:40 Torpeda Хочу поделится своими соображениями когда что лутш... May 15 2012, 09:24 anatolich Совершенно согласен.
Тем более, что ПикоБлэйз is f... May 15 2012, 10:57 Torpeda Цитата(anatolich @ May 15 2012, 13:57) ..... May 15 2012, 11:38  Postoroniy_V Цитата(Torpeda @ May 15 2012, 20:38) ...
... May 15 2012, 19:04   Torpeda Цитата(Postoroniy_V @ May 15 2012, 22:04)... May 16 2012, 13:16    Leka Цитата(Torpeda @ May 16 2012, 17:16) похо... May 16 2012, 13:33     Torpeda Цитата(Leka @ May 16 2012, 16:33) Это мед... May 16 2012, 13:52  Barktail Цитата(Torpeda @ May 15 2012, 16:12) таки... May 15 2012, 12:27   Torpeda Цитата(des00 @ May 16 2012, 09:45) так то... May 16 2012, 16:27    des00 Цитата(Torpeda @ May 16 2012, 11:27) Вот ... May 16 2012, 16:55     Torpeda Цитата(des00 @ May 16 2012, 19:55) переве... May 17 2012, 07:48      Bad0512 Цитата(Torpeda @ May 17 2012, 14:48) То ч... May 18 2012, 10:43       alexadmin Цитата(Bad0512 @ May 18 2012, 14:43) Я не... May 18 2012, 11:39        Bad0512 Цитата(alexadmin @ May 18 2012, 18:39) От... May 19 2012, 05:24    ReAl Цитата(Torpeda @ May 16 2012, 19:27) Вот ... May 19 2012, 08:06 anatolich И по сравнению с ниос Альтеры, не плохой бонус. May 15 2012, 13:26 SpyBot Подскажите, пожалуйста, почему как альтернативу пр... Jun 3 2012, 16:23 Victor® Цитата(SpyBot @ Jun 3 2012, 19:23) Но вед... Jun 4 2012, 12:15  Serhiy_UA Хотел бы добавить.
Конечные автоматы (КА) бывают с... Jun 5 2012, 05:27  Джеймс Цитата(Victor® @ Jun 4 2012, 16:15) Не фа... Jun 5 2012, 11:45
