> mkernel, новая ртось для ARM
MBR
сообщение Aug 8 2012, 06:47
Пользователь №: 59 748
Долго пытаясь доработать ртоси под свои нужды, понял, что ничего адекватного на рынке просто не существует и решил написать свою. Вот что получилось:
MKernel is embedded RTOS, based on microkernel architecture.
It's designed for ARM microprocessors, however, can be easily ported to any
32bit MCU.
Features:
- BSD License, royalty free, open source.
- Tickless. For system scheduling used 1 HPET timer and RTC. If RTC is
unavailable, another HPET timer can be used for RTC emulation (with full RTC
functionality)
- Hardware abstraction.RTOS is providing common interface for drivers.
- Standart microkernel syncronization: mutexes, events, semaphores, queues.
- Nested mutex priority inheritance
- Embedded dynamic memory manager, with ability of nested memory pools for
threads, dedicated system pool. Aligned malloc calls inside of any pools
- Safe and MPU ready. All supervisor-specific calls are wrapped around
swi/svc calls for context rising.
- Embedded libraries:
* printf/sprintf. Around 1k of code.
* time routines. POSIX-light
* single-linked list, double linked list, ring buffer, block ring buffer
* random number generation: hardware (if supported) or software
- Error handling:
* kill thread on system error, print error, if configured
* restart system on critical error, memory dump if configured
* handle error exceptions, decode address (if supported) and exception code
- Lot of debug features:
* memory dumps
* object marks
* thread profiling: name, uptime, stack allocated/current/used
* memory profiling: red-markings, pool free/allocated size, objects fragmentation
* stack profiling: supervisor allocated/current/used. Plus for arm7 - irq, fiq, abt
* configurable debug console
- Supported hardware:
* ARM7
* cortex-m3, drivers for:STM32 F2 (gpio, uart, rcc, timer, dma, rand)
Cortex-M3 features:
- Native SVC and pendSV support
ARM7 features:
- Nested interrupts
- FIQ support
- pendSV emulation, when returning to user/system context
И сразу из минусов: документация еще пока в стадии разработки, надеюсь, к концу сентября управлюсь. Примеры, надеюсь, на этой неделе будут готовы. На данный момент поддерживается только gcc.
Ссылка на проект на github: https://github.com/alexeyk13/mkernel
Lotor
сообщение Aug 8 2012, 06:56
Пользователь №: 28 866
Можете раскрыть более подробно этот пункт? Чем так Ваша ртос отличается от FreeRTOS, UCOS и других "неадекватных"?
Ковырял чукча отверткой в ухе, звук в телевизоре и пропал.
MBR
сообщение Aug 8 2012, 07:54
В сторону ucos я не смотрел принципиально - там gpl и этот недостаток для эмбеда перевесит все остальное.
Основной недостаток Free rtos, tn-kernel и им подобных, на мой взгляд, - тоже идеологический - это очень сильное абстрагирование от архитектуры, поддержка 8битников и т.п., в результате чего возможности аппаратной части используются не на полную. А из конкретных - различия, практически, по всем пунктам. Особенно, использование системных тиков для шедулера задач. Из плюсов free rtos - безусловно, размер кода (правда, если во free rtos включить все, что есть в mkernel, я сомневаюсь, что получится меньше).
Соглашусь, слово "адекватный", пожалуй, слишком грубо.
Цитата(IgorKossak @ Aug 8 2012, 11:10) *
В папках arch/arm arch/cortex_m3 файлы delay_*.s желательно переименовать в delay_*.S дабы не гневить Eclipse (и ради однообразия тоже).
Спасибо за совет, сделаю в следующем коммите. Я делал как раз ради различия, чтобы было понятно, что файл обрабатывается препроцессором или нет.
Сообщение отредактировал MBR - Aug 8 2012, 07:55
- MBR   mkernel   Aug 8 2012, 06:47
- - IgorKossak   В папках arch/arm arch/cortex_m3 файлы delay_*.s ж...   Aug 8 2012, 07:10
- - haker_fox   Знаете, чего мне не хватает во встраиваемой РТОС? ...   Aug 8 2012, 08:27
|- - MBR   Цитата(haker_fox @ Aug 8 2012, 12:27) Зна...   Aug 8 2012, 09:13
- - MBR   0.1.3 + pin keyboard module with debounce logic ...   Aug 15 2012, 08:34
|- - haker_fox   QUOTE (MBR @ Aug 15 2012, 17:34) 0.1.3 +...   Aug 15 2012, 12:42
- - MBR   Вернулся из отпуска. 0.1.4 + new module: software...   Sep 12 2012, 15:34
|- - _Артём_   Цитата(MBR @ Sep 12 2012, 18:34) Вернулся...   Sep 12 2012, 16:32
|- - MBR   Цитата(_Артём_ @ Sep 12 2012, 20:32) Кста...   Sep 12 2012, 16:43
|- - _Артём_   Цитата(MBR @ Sep 12 2012, 19:43) Давайте ...   Sep 12 2012, 17:17
- - MBR   Цитата../../arch/hw_config.h:41:31...   Sep 12 2012, 18:13
- - _Артём_   Цитата(MBR @ Sep 12 2012, 21:13) Собствен...   Sep 12 2012, 20:21
- - AHTOXA   Цитата(_Артём_ @ Sep 13 2012, 02:21) Off:...   Sep 13 2012, 02:35
- - MBR   Цитата(_Артём_ @ Sep 13 2012, 00:21) Нечи...   Sep 13 2012, 04:45
- - andrew_b   Цитата(MBR @ Sep 13 2012, 08:45) Все-таки...   Sep 13 2012, 10:43
- - MBR   Цитата(andrew_b @ Sep 13 2012, 14:43) gcc...   Sep 13 2012, 11:06
RSS Текстовая версия Сейчас: 27th July 2025 - 16:13
Страница сгенерированна за 0.13661 секунд с 7
