> lwip + FreeRTOS
Escave
сообщение Mar 9 2014, 16:21
Пользователь №: 76 690
Здравствуйте. Продолжаю разбираться с lwip. Сейчас хочу запустить его на STM32F4Discovery с операционкой FreeRTOS. На диске, который шел с платой, есть пример. И в нем файлик:
CODE
/* Includes ------------------------------------------------------------------*/
#include "stm32f4xx_it.h"
#include "main.h"
#include "stm32f4x7_eth.h"
/* Scheduler includes */
#include "FreeRTOS.h"
#include "task.h"
#include "queue.h"
/* lwip includes */
#include "lwip/sys.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
extern xSemaphoreHandle s_xSemaphore;
/* Private function prototypes -----------------------------------------------*/
extern void xPortSysTickHandler(void);
/* Private functions ---------------------------------------------------------*/
/* Cortex-M4 Processor Exceptions Handlers */
* @brief This function handles NMI exception.
* @param None
* @retval None
void NMI_Handler(void)
* @brief This function handles Hard Fault exception.
* @param None
* @retval None
void HardFault_Handler(void)
/* Go to infinite loop when Hard Fault exception occurs */
while (1)
* @brief This function handles Memory Manage exception.
* @param None
* @retval None
void MemManage_Handler(void)
/* Go to infinite loop when Memory Manage exception occurs */
while (1)
* @brief This function handles Bus Fault exception.
* @param None
* @retval None
void BusFault_Handler(void)
/* Go to infinite loop when Bus Fault exception occurs */
while (1)
* @brief This function handles Usage Fault exception.
* @param None
* @retval None
void UsageFault_Handler(void)
/* Go to infinite loop when Usage Fault exception occurs */
while (1)
* @brief This function handles SVCall exception.
* @param None
* @retval None
void SVC_Handler(void)
* @brief This function handles Debug Monitor exception.
* @param None
* @retval None
void DebugMon_Handler(void)
* @brief This function handles PendSVC exception.
* @param None
* @retval None
void PendSV_Handler(void)
* @brief This function handles SysTick Handler.
* @param None
* @retval None
void SysTick_Handler(void)
xPortSysTickHandler();
* @brief This function handles ethernet DMA interrupt request.
* @param None
* @retval None
void ETH_IRQHandler(void)
portBASE_TYPE xHigherPriorityTaskWoken = pdFALSE;
/* Frame received */
if ( ETH_GetDMAFlagStatus(ETH_DMA_FLAG_R) == SET) {
/* Give the semaphore to wakeup LwIP task */
xSemaphoreGiveFromISR( s_xSemaphore, &xHigherPriorityTaskWoken );
/* Clear the interrupt flags. */
/* Clear the Eth DMA Rx IT pending bits */
ETH_DMAClearITPendingBit(ETH_DMA_IT_R);
ETH_DMAClearITPendingBit(ETH_DMA_IT_NIS);
/* Switch tasks if necessary. */
if ( xHigherPriorityTaskWoken != pdFALSE ) {
portEND_SWITCHING_ISR( xHigherPriorityTaskWoken );
При компиляции пишет ошибку: error: unknown type name 'xSemaphoreHandle'
Попробовал дописать #include "semphr.h", но стал выдавать undefined reference to `s_xSemaphore'. В настройках FreeRTOS семафоры, вроде бы, включил
CODE
#ifndef FREERTOS_CONFIG_H
#define FREERTOS_CONFIG_H
* Application specific definitions.
* These definitions should be adjusted for your particular hardware and
* application requirements.
* THESE PARAMETERS ARE DESCRIBED WITHIN THE 'CONFIGURATION' SECTION OF THE
* FreeRTOS API DOCUMENTATION AVAILABLE ON THE FreeRTOS.org WEB SITE.
* See http://www.freertos.org/a00110.html.
#define configUSE_PREEMPTION 1
#define configUSE_IDLE_HOOK 0
#define configUSE_TICK_HOOK 0
#define configCPU_CLOCK_HZ ( ( unsigned long ) 168000000 )
#define configTICK_RATE_HZ ( ( portTickType ) 1000 )
#define configMAX_PRIORITIES ( ( unsigned portBASE_TYPE ) 5 )
#define configMINIMAL_STACK_SIZE ( ( unsigned short ) 120 )
#define configTOTAL_HEAP_SIZE ( ( size_t ) ( 18 * 1024 ) )
#define configMAX_TASK_NAME_LEN ( 16 )
#define configUSE_TRACE_FACILITY 0
#define configUSE_16_BIT_TICKS 0
#define configIDLE_SHOULD_YIELD 1
/* Co-routine definitions. */
#define configUSE_CO_ROUTINES 0
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
#define configUSE_MUTEXES 1
#define configUSE_COUNTING_SEMAPHORES 1
#define configUSE_ALTERNATIVE_API 0
#define configCHECK_FOR_STACK_OVERFLOW 0
#define configUSE_RECURSIVE_MUTEXES 0
#define configQUEUE_REGISTRY_SIZE 0
#define configGENERATE_RUN_TIME_STATS 0
/* Set the following definitions to 1 to include the API function, or zero
to exclude the API function. */
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 1
#define INCLUDE_vTaskCleanUpResources 0
#define INCLUDE_vTaskSuspend 0
#define INCLUDE_vTaskDelayUntil 0
#define INCLUDE_vTaskDelay 1
#define INCLUDE_uxTaskGetStackHighWaterMark 0
/* This is the raw value as per the Cortex-M3 NVIC. Values can be 255
(lowest) to 0 (1?) (highest). */
#define configKERNEL_INTERRUPT_PRIORITY 255
/* !!!! configMAX_SYSCALL_INTERRUPT_PRIORITY must not be set to zero !!!!
See http://www.FreeRTOS.org/RTOS-Cortex-M3-M4.html. */
#define configMAX_SYSCALL_INTERRUPT_PRIORITY 191 /* equivalent to 0xb0, or priority 11. */
/* This is the value being used as per the ST library which permits 16
priority values, 0 to 15. This must correspond to the
configKERNEL_INTERRUPT_PRIORITY setting. Here 15 corresponds to the lowest
NVIC value of 255. */
#define configLIBRARY_KERNEL_INTERRUPT_PRIORITY 15
#endif /* FREERTOS_CONFIG_H */
В чем проблема?
Сообщение отредактировал IgorKossak - Mar 9 2014, 19:49
Причина редактирования: [codebox] для длинного кода, [code] - для короткого!!!
Escave
сообщение Mar 9 2014, 20:40
Вобщем, нашел я тут какой-то код для lwip+freertos. И там такая штука:
Есть файл stm32f4xx_it.c
CODE
#include "main.h"
* @param None
* @retval None
* @param None
* @retval None
while (1)
* @param None
* @retval None
while (1)
* @param None
* @retval None
while (1)
* @param None
* @retval None
while (1)
* @param None
* @retval None
* @param None
* @retval None
* @param None
* @retval None
* @param None
* @retval None
/* Update the LocalTime by adding SYSTEMTICK_PERIOD_MS each SysTick interrupt */
Time_Update();
С ним без FreeRTOS lwip прекрасно работает. Но теперь нужно запустить и lwip. Заменяю в этом файле год на код для FreeRTOS
CODE
#include "main.h"
#include "task.h"
#include "queue.h"
/* lwip includes */
* @param None
* @retval None
* @param None
* @retval None
while (1)
* @param None
* @retval None
while (1)
* @param None
* @retval None
while (1)
* @param None
* @retval None
while (1)
* @param None
* @retval None
* @param None
* @retval None
* @param None
* @retval None
* @param None
* @retval None
* @param None
* @retval None
/* STM32F4xx Peripherals Interrupt Handlers */
/* Add here the Interrupt Handler for the used peripheral(s) (PPP), for the */
/* available peripheral interrupt handler's name please refer to the startup */
/* file (startup_stm32f4xx.s). */
* @brief This function handles PPP interrupt request.
* @param None
* @retval None
/*void PPP_IRQHandler(void)
И ничего не работает sad.gif Что вообще делать? Почему по отдельности lwip и freertos работают, а вместе не хотят?
Сообщение отредактировал IgorKossak - Mar 10 2014, 10:25
kolobok0
сообщение Mar 10 2014, 04:54
практикующий тех. волшебник
Пользователь №: 8 417
Цитата(Escave @ Mar 10 2014, 00:40) *
...И ничего не работает sad.gif Что вообще делать? Почему по отдельности lwip и freertos работают, а вместе не хотят?
а на Ваш взгляд что в этом файлике, и чем отличаются эти два файла?
и ышо...
это не всё различие. залезьте...впрочем ответьте на вопросы, далее сами найдёте...
RSS Текстовая версия Сейчас: 25th July 2025 - 03:40
Страница сгенерированна за 0.01386 секунд с 7
