STM32F4 ADC Excessive noise level, Noise level is over 5LSB |
Sep 23 2015, 15:34
Из: USA
Пользователь №: 17 672
Цитата(scifi @ Sep 23 2015, 11:17)  На схему и на разводку смотреть надо. У меня такого безобразия (32 отсчёта) даже близко не было. Thanks for reply. Unfortunately it is out of my control... Schematics looks clean, nothing really suspicious. Traces, routing and other EE stuff is over my level of expertise.
Sep 23 2015, 18:47
Из: Тверь, Россия
Пользователь №: 39 321
Цитата(pitt @ Sep 23 2015, 18:34)  Thanks for reply. Unfortunately it is out of my control... Schematics looks clean, nothing really suspicious. Traces, routing and other EE stuff is over my level of expertise. Could you share your code? It seems that there are some mistakes in initialzation of GPIO, RCC or ADC. Check it again.
Sep 24 2015, 15:55
Из: USA
Цитата(EmbedElektrik @ Sep 23 2015, 14:47)  Could you share your code? It seems that there are some mistakes in initialzation of GPIO, RCC or ADC. Check it again. All I can share is values of the ADC registers just let me know which do you need. They are fine with me. Problems with RCC and or GPIO is nonsense: one wouldn't be able to get any readings, but I do - my problem is noise. I suspect that something with the board(made in China) but don't have EE expertise to prove it right or wrong. The power and Vref are fine: checked with my scope. I'm talking about raw(unfiltered) readings. Regardless, the other chat over here is clearly off topic. I'm native Russian speaker but don't and never will have blind typing skills. Replies in Russian are not a problem at all except may be terminology. Thank you all for response.
Sep 24 2015, 17:27
Из: USA
Цитата(Ruslan1 @ Sep 24 2015, 12:39)  1. Непонятно как Вы определили что у Вас такой шум. Сохраните в массив последовательно проведенные измерения - коды АЦП (хотя бы за 20 ms для начала) и покажите, чтобы доказать наличие шума и посмотреть его параметры. 2. И что именно Вы измеряете? 3. Ну и покажите часть схемы, критичнуя для АЦП: все питания, Vref, схема измеряемого аналогового входа. 1. I'm storing min,max, mean 2. digital potentiometer 3. Copy from reference design. As I mentioned before, traces and routing is under umbrella of suspicion
Sep 24 2015, 18:19
Из: Кишинев
Пользователь №: 15 025
Цитата(pitt @ Sep 24 2015, 20:27)  1. I'm storing min,max, mean 2. digital potentiometer 3. Copy from reference design. As I mentioned before, traces and routing is under umbrella of suspicion 1. Этого недостаточно. дайте массив значений АЦП- это, вероятно, даст информацию о природе шума 2. схему подключения потенциометра приведите. от чего он питается и что за напряжение делит? И там не сто килоом? Просто делитель на двух резисторах по паре килоом от Vref на вход АЦП подключите, это исключит кучу версий. 3. Схему приведите. " traces and routing is under umbrella of suspicion" - это, конечно красиво сказано, но неинформативно. С разводкой- очень маловероятно нагенерировать шума на 25 милливольт пик-пик (референс у Вас около 3.3 V ?).
Sep 24 2015, 19:22
Из: USA
Цитата(Ruslan1 @ Sep 24 2015, 14:19)  1. Этого недостаточно. дайте массив значений АЦП- это, вероятно, даст информацию о природе шума How come? What the difference does it make to see the graph in time or just its parameters? I have plotted it and it is noise("BORODA") Цитата(Ruslan1 @ Sep 24 2015, 14:19)  2. схему подключения потенциометра приведите. от чего он питается и что за напряжение делит? И там не сто килоом? Просто делитель на двух резисторах по паре килоом от Vref на вход АЦП подключите, это исключит кучу версий. Sorry, it is impossible. Scoped the output though - solid as a rock. Цитата(Ruslan1 @ Sep 24 2015, 14:19)  3. Схему приведите. " traces and routing is under umbrella of suspicion" - это, конечно красиво сказано, но неинформативно. С разводкой- очень маловероятно нагенерировать шума на 25 милливольт пик-пик (референс у Вас около 3.3 V ?). Nothing there...Copy and paste from STM32F4G-EVAL. One to one except more inputs are used i.e. more and different pins. Vref = 2.048V (LM4040D20IDBZR)
Sep 24 2015, 19:47
Из: Кишинев
Цитата(pitt @ Sep 24 2015, 22:22)  How come? What the difference does it make to see the graph in time or just its parameters? I have plotted it and it is noise("BORODA")
Nothing there...Copy and paste from STM32F4G-EVAL. One to one except more inputs are used i.e. more and different pins. Vref = 2.048V (LM4040D20IDBZR) Я пас. Данных-нет. Схемы "что подается на вход"-нет. Схемы "как запитан МК и что с референсом"- нет. Ну ладно, сделал усилие и посмотрел кит. Ну что же, мне почему-то кажется, что ответ на вопрос "откуда 16 mV пик-пик шумы" не так уж и сложно найти.
pitt STM32F4 ADC Excessive noise level Sep 23 2015, 15:06         pitt Цитата(Ruslan1 @ Sep 24 2015, 15:47) Я па... Sep 24 2015, 20:07 ШСА Цитата(scifi @ Sep 23 2015, 18:17) На схе... Sep 23 2015, 20:42 Genadi Zawidowski Шум такого же порядка наблюдался при измерении вст... Sep 23 2015, 15:18 ViKo Во-первых, 5 LSB != 32.
Питание посмотрите, на... Sep 24 2015, 05:15 scifi Цитата(ViKo @ Sep 24 2015, 08:15) Во-перв... Sep 24 2015, 06:13 Golikov A. а почему 5 младших меняющихся бит не дают 32 ампли... Sep 24 2015, 06:23 scifi Цитата(Golikov A. @ Sep 24 2015, 09:23) а... Sep 24 2015, 06:33 Golikov A. а вот и нет...
LSB - Least Significant Bit
то есть... Sep 24 2015, 07:45 scifi Цитата(Golikov A. @ Sep 24 2015, 10:45) а... Sep 24 2015, 07:52 smalcom во-первых, LSB - младший значащий бит. Выборка/отс... Sep 24 2015, 08:19 ViKo Не дурите голову. 5 LSB - 5 единиц младшего разряд... Sep 24 2015, 09:36 Tanya Цитата(ViKo @ Sep 24 2015, 12:36) Не дури... Sep 24 2015, 10:47  ViKo Цитата(Tanya @ Sep 24 2015, 13:47) Не дур... Sep 24 2015, 11:37 Ruslan1 Цитата(pitt @ Sep 23 2015, 18:06) Noise l... Sep 24 2015, 11:10 Tanya Из признания ТС следует, что он прекрасно понимает... Sep 24 2015, 11:22  Ruslan1 Цитата(Tanya @ Sep 24 2015, 14:22) Из при... Sep 24 2015, 11:31   Tanya Цитата(Ruslan1 @ Sep 24 2015, 14:31) А мо... Sep 24 2015, 11:48  scifi Цитата(Tanya @ Sep 24 2015, 14:22) но у н... Sep 24 2015, 12:00   Ruslan1 Цитата(scifi @ Sep 24 2015, 15:00) У меня... Sep 24 2015, 12:13 ViKo А осциллограф какой был? Хороший? Sep 24 2015, 18:11 Golikov A. а поподробнее, мне тоже интересно откуда шум Sep 24 2015, 20:07 Ruslan1 Цитата(Golikov A. @ Sep 24 2015, 23:07) а... Sep 24 2015, 20:20 Genadi Zawidowski Даташит:
Цитата4. If VREF+ pin is present, it must... Sep 24 2015, 20:17 Genadi Zawidowski Предлагаю вопрошающему измерить встроенную опору и... Sep 24 2015, 20:27 Golikov A. ЦитатаДык, вестимо, цифровое питание -оно не бесшу... Sep 24 2015, 20:33 pitt The problem isn't noise which is totally under... Sep 24 2015, 20:44 smalcom а почему тема не в разделе для англоязычников?
---... Sep 24 2015, 21:01 Genadi Zawidowski "ТС" это вы.
Прошу не игнорировать вопро... Sep 25 2015, 05:30 Golikov A. TC = topic starter Sep 25 2015, 06:34 pitt Цитата(Golikov A. @ Sep 25 2015, 02:34) T... Sep 25 2015, 13:08 ViKo Гистограмма распределения результатов измерения по... Sep 25 2015, 07:04 smalcom Мде. Замкнутый круг. Или языковой барьер... Sep 25 2015, 13:33 Genadi Zawidowski Извините, а как же Вы пишите програму?
Ну пожалуй... Sep 25 2015, 16:46 pitt Цитата(Genadi Zawidowski @ Sep 25 2015, 12... Sep 25 2015, 17:28 Genadi Zawidowski Сперва без JSQR протестируйте.. Sep 25 2015, 17:33 pitt Цитата(Genadi Zawidowski @ Sep 25 2015, 13... Sep 25 2015, 17:43  pitt Цитата(pitt @ Sep 25 2015, 13:43) ?
It is... Sep 26 2015, 21:14 smalcom абсолютные значения температуры там неверны, как и... Sep 27 2015, 04:13 pitt Пожалуйста указывайте конкретные ссылки на докумен... Sep 27 2015, 14:29 smalcom ЦитатаПожалуйста указывайте конкретные ссылки на д... Sep 27 2015, 16:39 pitt Не уверен, что Ф1 и Ф4 одинаковы. Насколько я в ку... Sep 27 2015, 17:40 smalcom я поражён, вам реально впадлу открыть документ и п... Sep 27 2015, 19:33 pitt Цитата(smalcom @ Sep 27 2015, 15:33) я по... Sep 27 2015, 20:42 Rash Посчитайте выходное сопротивление схемы, по докам ... Sep 27 2015, 20:44 pitt Цитата(Rash @ Sep 27 2015, 16:44) Посчита... Sep 27 2015, 21:02 Golikov A. так может пора к ее пойти и спросить что это за ее... Sep 28 2015, 04:18 Ruslan1 Цитата(Golikov A. @ Sep 28 2015, 07:18) т... Sep 28 2015, 05:04 Rash Ну так посадите рядом того кто понимает и разберит... Sep 28 2015, 05:26 smalcom ЦитатаНе понимаю разработчиков embedded
громко ска... Sep 28 2015, 07:33 scifi Пардон за офтопик, но это какой-то театр абсурда..... Sep 28 2015, 08:00 ViKo "Программист не виноват", похоже. Здесь ... Sep 28 2015, 09:21 pitt Беда, коль пироги начнет печи сапожник,
А сапоги т... Sep 28 2015, 12:10 ViKo Еще хорошо, когда к советам прислушиваются. Sep 28 2015, 12:13 smalcom ЦитатаЕще хорошо, когда к советам прислушиваются. ... Sep 28 2015, 12:44 pitt Отвечаю на свои вопросы сам: может кому-нибудь не ... Sep 28 2015, 23:13 smalcom сразу содержание документов выкладывайте. вдруг ва... Sep 29 2015, 00:45
