> Вопрос про phy ethernet, stm32f407 + KSZ8873
Granadoespada
сообщение Sep 5 2016, 12:49
Пользователь №: 89 981
Здравствуйте! Есть микроконтроллер и phy KSZ8873 делаю инициализацию пинов
CODE
void eth_gpio_config()
GPIO_InitTypeDef GPIO_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOB |
RCC_AHB1Periph_GPIOC, ENABLE);
/* Configure PA2 as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
//GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_ETH);
/* Configure PC1, PC2 and PC3 as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource1, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource2, GPIO_AF_ETH);
/* Configure PB5, PB8, PB11, PB12 and PB13 as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_11 |
GPIO_Pin_12 | GPIO_Pin_13;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource8, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource11, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource12, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_ETH);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_3;
// GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_PinAFConfig(GPIOA, GPIO_PinSource0, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource1, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource3, GPIO_AF_ETH);
/* Configure PB10 as input */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
// GPIO_ResetBits(GPIOB, GPIO_Pin_10); /* FIXME: fucking workaround */
GPIO_PinAFConfig(GPIOB, GPIO_PinSource10, GPIO_AF_ETH);
/* Configure PC3 as input */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
GPIO_PinAFConfig(GPIOC, GPIO_PinSource3, GPIO_AF_ETH);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_ETH);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
GPIO_PinAFConfig(GPIOC, GPIO_PinSource4, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource5, GPIO_AF_ETH);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
GPIO_PinAFConfig(GPIOB, GPIO_PinSource0, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource1, GPIO_AF_ETH);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
GPIO_PinAFConfig(GPIOA, GPIO_PinSource8, GPIO_AF_MCO);
дальше идет конфигурация MAC_DMA
CODE
void eth_mac_dma_config()
ETH_InitTypeDef ETH_InitStructure;
/* Enable SYSCFG clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
/* Включение частот ETHERNET */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_ETH_MAC | RCC_AHB1Periph_ETH_MAC_Tx |
RCC_AHB1Periph_ETH_MAC_Rx, ENABLE);
/* MII/RMII Media interface selection --------------------------------------*/
SYSCFG_ETH_MediaInterfaceConfig(SYSCFG_ETH_MediaInterface_MII);
RCC_MCO1Config(RCC_MCO1Source_HSE, RCC_MCO1Div_1);
SYSCFG_CompensationCellCmd(ENABLE);
/* Перзагрузка ETHERNET на шине AHB */
ETH_DeInit();
/* Программная перезагрузка */
ETH_SoftwareReset();
/* Ожидание программной перезагрузки */
while(ETH_GetSoftwareResetStatus() == SET);
/* Настройка ETHERNET */
ETH_StructInit(&ETH_InitStructure);
/* Настройка параметров MAC */
ETH_InitStructure.ETH_AutoNegotiation = ETH_AutoNegotiation_Enable;
ETH_InitStructure.ETH_LoopbackMode = ETH_LoopbackMode_Disable;
ETH_InitStructure.ETH_RetryTransmission = ETH_RetryTransmission_Disable;
ETH_InitStructure.ETH_AutomaticPadCRCStrip = ETH_AutomaticPadCRCStrip_Disable;
ETH_InitStructure.ETH_ReceiveAll = ETH_ReceiveAll_Disable;
ETH_InitStructure.ETH_BroadcastFramesReception = ETH_BroadcastFramesReception_Enable;
ETH_InitStructure.ETH_PromiscuousMode = ETH_PromiscuousMode_Disable;
ETH_InitStructure.ETH_MulticastFramesFilter = ETH_MulticastFramesFilter_Perfect;
ETH_InitStructure.ETH_UnicastFramesFilter = ETH_UnicastFramesFilter_Perfect;
ETH_InitStructure.ETH_ChecksumOffload = ETH_ChecksumOffload_Enable;
/* Настройка параметров DMA */
ETH_InitStructure.ETH_DropTCPIPChecksumErrorFrame = ETH_DropTCPIPChecksumErrorFrame_Enable;
ETH_InitStructure.ETH_ReceiveStoreForward = ETH_ReceiveStoreForward_Enable;
ETH_InitStructure.ETH_TransmitStoreForward = ETH_TransmitStoreForward_Enable;
ETH_InitStructure.ETH_Speed = ETH_Speed_100M;
ETH_InitStructure.ETH_ForwardErrorFrames = ETH_ForwardErrorFrames_Disable;
ETH_InitStructure.ETH_ForwardUndersizedGoodFrames = ETH_ForwardUndersizedGoodFrames_Disable;
ETH_InitStructure.ETH_SecondFrameOperate = ETH_SecondFrameOperate_Enable;
ETH_InitStructure.ETH_AddressAlignedBeats = ETH_AddressAlignedBeats_Enable;
ETH_InitStructure.ETH_FixedBurst = ETH_FixedBurst_Enable;
ETH_InitStructure.ETH_RxDMABurstLength = ETH_RxDMABurstLength_32Beat;
ETH_InitStructure.ETH_TxDMABurstLength = ETH_TxDMABurstLength_32Beat;
ETH_InitStructure.ETH_DMAArbitration = ETH_DMAArbitration_RoundRobin_RxTx_2_1;
/* Применение настроек Ethernet */
ETH_Init(&ETH_InitStructure, PHY_ADDRESS);
/* Включение прерываний Ethernet Rx */
ETH_DMAITConfig(ETH_DMA_IT_NIS | ETH_DMA_IT_R, ENABLE);
Почему то не может выйти из функции ожидания программной перезагрузки while(ETH_GetSoftwareResetStatus() == SET).
Может кто сможет подсказать что делаю не так?
За ранее спасибо.
Сообщение отредактировал IgorKossak - Sep 5 2016, 15:13
Причина редактирования: [codebox] для длинного кода. [code]-для короткого!!!
Jury093
сообщение Sep 5 2016, 15:51
Пользователь №: 13 050
почитайте для начала Id физики
High = 0x0022
Low = 0x1430
возможно у вас где-то логическая или физическая ошибка вкралась в интерфейс.. прочитаете правильно, тогда будете разбираться с неготовностью по ресету..
Granadoespada
сообщение Sep 6 2016, 08:48
High = 0x0022
Low = 0x1430
А где это найти?
Jury093
сообщение Sep 6 2016, 08:56
Цитата(Granadoespada @ Sep 6 2016, 11:48) *
А где это найти?
как где? в доке на чип конечно.. страница 50
Granadoespada
сообщение Sep 6 2016, 09:14
извините за не корректный вопрос. Я имел ввиду а где это в программе может быть использоваться?
iosifk
сообщение Sep 6 2016, 09:23
Из: спб
Пользователь №: 8 369
Как где? Вы уверены, что пишите и читаете из регистров PHY, а не из "пустого места"? Физический адрес PHY соответствует тому, который задан в программе? Если лень изучать матчасть, то перебирайте адреса PHY до тех пор, пока не найдете требуемое ID. А если не найдете совсем, то значит что-то там померло...
www.iosifk.narod.ru
Granadoespada
сообщение Sep 6 2016, 09:35
Просто я на сколько на данный момент понимаю, как у меня происходит на данный момент работа в моем проекте то получается:
- Сначала идет инициализация GPIO на которых сидит Ethernet;
- Потом идет инициализация eth_mac_dma, где происходит следующее:
ETH_DeInit();
и вот на "ожидании программной перезагрузки" у меня и встает программа и крутиться в бесконечном цикле. Я на сколько понимаю у меня до работы с регистрами не доходит или я не правильно понимаю?
iosifk
сообщение Sep 6 2016, 09:47
Из: спб
ETH_DeInit();
Есть интерфейс MII и есть служебный интерфейс, который не MII. И именно по нему идет запись и чтение регистров PHY.
Тут надо посмотреть описание PHY, найти выводы этого интерфейса и проследить, к каким выводам процессора они подключены. И посмотреть, как зашит адрес PHY. Ну и до кучи, PHY любит длительный сигнал Сброс.... Все это надо проверить.
То, что относится к МАС у Вас сидит в процессоре. Но еще какие-то выводы процессора должны быть задействованы под служебный интерфейс. Поищите их в Вашей инициализации. И если их нет, то как должен произойти "ETH_SoftwareReset();"? Это перезагрузка МАС или PHY? Если PHY то скорее всего это и есть запись в регистры PHY и попытка прочесть оттуда статус...
www.iosifk.narod.ru
Granadoespada
сообщение Sep 6 2016, 10:04
Вот также инициализация пинов
CODE
/* Enable GPIOs clocks */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOB | RCC_AHB1Periph_GPIOC, ENABLE);
/* Configure MCO (PA8) */
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
//GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_SetBits(GPIOA, GPIO_Pin_8);
#ifdef MII_MODE /* Mode MII with STM322xG-EVAL */
/* Output HSE clock (25MHz) on MCO pin (PA8) to clock the PHY */
#elif defined RMII_MODE /* Mode RMII with STM322xG-EVAL */
SYSCFG_ETH_MediaInterfaceConfig(SYSCFG_ETH_MediaInterface_RMII);
#endif
/* Ethernet pins configuration ************************************************/
ETH_MDIO -------------------------> PA2
ETH_MDC --------------------------> PC1
ETH_MII_CRS ----------------------> PA0
ETH_MII_COL ----------------------> PA3
ETH_MII_RX_ER --------------------> PB10
ETH_MII_RXD2 ---------------------> PC4
ETH_MII_RXD3 ---------------------> PC5
ETH_MII_TX_CLK -------------------> PC3
ETH_MII_TXD2 ---------------------> PC2
ETH_MII_TXD3 ---------------------> PB8
ETH_MII_RX_CLK/ETH_RMII_REF_CLK---> PA1
ETH_MII_RX_DV/ETH_RMII_CRS_DV ----> PA7
ETH_MII_RXD0/ETH_RMII_RXD0 -------> PC4
ETH_MII_RXD1/ETH_RMII_RXD1 -------> PC5
ETH_MII_TX_EN/ETH_RMII_TX_EN -----> PB11
ETH_MII_TXD0/ETH_RMII_TXD0 -------> PB12
ETH_MII_TXD1/ETH_RMII_TXD1 -------> PB13
/* Configure PA0, PA1, PA2, PA3 and PA7 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_7;
/* Configure PB0, PB1, PB8, PB10, PB11, PB12 and PB13 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_8 | GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13;
GPIO_PinAFConfig(GPIOB, GPIO_PinSource10,GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource11,GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource12,GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource13,GPIO_AF_ETH);
/* Configure PC1, PC2, PC3, PC4 and PC5 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5;
перезагрузка идет MAC на сколько я понимаю. вот код
CODE
@brief Resets all MAC subsystem internal registers and logic.
* @param None
* @retval None
void ETH_SoftwareReset(void)
/* Set the SWR bit: resets all MAC subsystem internal registers and logic */
/* After reset all the registers holds their respective reset values */
ETH->DMABMR ^= ETH_DMABMR_SR;
* @brief Checks whether the ETHERNET software reset bit is set or not.
* @param None
* @retval The new state of DMA Bus Mode register SR bit (SET or RESET).
FlagStatus ETH_GetSoftwareResetStatus(void)
FlagStatus bitstatus = RESET;
if((ETH->DMABMR & ETH_DMABMR_SR) != (uint32_t)RESET)
GPIOB->ODR ^= GPIO_Pin_9;
bitstatus = SET;
for(int i = 0; i < 1000000; i++);
else
bitstatus = RESET;
return bitstatus;
Сообщение отредактировал IgorKossak - Sep 6 2016, 12:17
Jury093
сообщение Sep 6 2016, 11:13
я плохо знаком с архитектурой stm32 - у вас этот пин (PB9) инициирован как надо?
Granadoespada
сообщение Sep 6 2016, 12:29
Этот пин относиться к светодиоду он тут не причем.
Integro
сообщение Sep 6 2016, 12:42
Пользователь №: 54 460
Схему бы нам!
Вы пользуете MII или RMII интерфейс?
Granadoespada
сообщение Sep 6 2016, 13:22
Цитата(Integro @ Sep 6 2016, 13:42) *
Схему бы нам!
MII, и у меня сразу такой вопрос у меня пин PA1 отвечает за ETH_MII_RX_CLK как на него можно завести частоту 25 МГц?
Схемы пока нет возможности предоставить
Integro
сообщение Sep 6 2016, 13:33
Как было сказано в начале темы, 25MHz делает PHY.
В коде пользуется дефайн MII_MODE, он обьявлен?
Если схемы нет, проверь еще раз инициализацию пинов, и наличие клоков!!!
UPD: клока на проце нет, вижу. Теперь нужно проверить все напряжения на PHY и клок самого PHY. От чего тактируется PHY?
Granadoespada
сообщение Sep 6 2016, 13:35
А если PHY не делает 25 MHz?
Integro
сообщение Sep 6 2016, 13:43
Сообщение #16
Granadoespada
сообщение Sep 6 2016, 13:50
Сообщение #17
PHY тактируется от по MCO от микроконтроллера HSE 25MHz
Integro
сообщение Sep 6 2016, 14:07
Сообщение #18
и...? Частота в норме?
Granadoespada
сообщение Sep 6 2016, 14:11
Сообщение #19
Частота в норме. Сигнал сброса буду проверять.
scifi
сообщение Sep 6 2016, 14:17
Сообщение #20
Пользователь №: 25 136
Кстати, схему кто рисовал? KSZ8873 может работать в разных режимах, там нельзя просто всё бросить в кучу и рассчитывать, что оно заработает. Как бы требуется понимание того, как это работает. Впрочем, это никогда не вредно.
Granadoespada
сообщение Sep 7 2016, 05:26
Сообщение #21
Схему делал человек, который в этом разбирается. Он делал связку stm32f103 + KSZ8873. Взяли данное устройство и на том устройстве тактирующий сигнал от PHY приходит скорее всего причина в отсутсвии сигнала от PHY. Сейчас будем выяснять почему он не приходит.
Всем большое спасибо за помощь. Как будет результат то сразу отпишусь.
- Granadoespada   Вопрос про phy ethernet   Sep 5 2016, 12:49
- - scifi   Цитата(Granadoespada @ Sep 5 2016, 15:49)...   Sep 5 2016, 13:15
|- - Granadoespada   Цитата(scifi @ Sep 5 2016, 13:15) Было та...   Sep 5 2016, 13:21
|- - scifi   Цитата(Granadoespada @ Sep 5 2016, 16:21)...   Sep 5 2016, 14:08
|- - Granadoespada   Цитата(scifi @ Sep 5 2016, 14:08) Тактиру...   Sep 5 2016, 14:29
|- - scifi   Цитата(Granadoespada @ Sep 5 2016, 17:29)...   Sep 5 2016, 14:33
- - jcxz   А что значит "нерестится"? Икру мечет?   Sep 5 2016, 13:59
|- - Granadoespada   Цитата(jcxz @ Sep 5 2016, 13:59) А что зн...   Sep 5 2016, 14:04
- - Obam   Из жизни эмбеддера рыбака: мечет икру (нерестится)...   Sep 5 2016, 14:02
- - x893   Путина началась ? Тогда отнерестится.   Sep 5 2016, 14:05
|- - Granadoespada   Цитата(x893 @ Sep 5 2016, 14:05) Путина н...   Sep 5 2016, 14:08
|- - iosifk   Цитата(Granadoespada @ Sep 6 2016, 13:04)...   Sep 6 2016, 10:41
||- - Granadoespada   Цитата(iosifk @ Sep 6 2016, 11:41) Ну мне...   Sep 6 2016, 10:46
||- - scifi   Цитата(iosifk @ Sep 6 2016, 13:41) Ну мне...   Sep 6 2016, 13:23
||- - Granadoespada   Цитата(scifi @ Sep 6 2016, 14:23) Путаете...   Sep 6 2016, 13:29
||- - scifi   Цитата(Granadoespada @ Sep 6 2016, 16:29)...   Sep 6 2016, 13:35
||- - Integro   Если схема включения уже отлажена, я бы порекоменд...   Sep 7 2016, 07:05
||- - Granadoespada   Цитата(Integro @ Sep 7 2016, 08:05) Если ...   Sep 7 2016, 09:57
||- - iosifk   Цитата(Granadoespada @ Sep 7 2016, 12:57)...   Sep 7 2016, 10:06
||- - Granadoespada   Цитата(iosifk @ Sep 7 2016, 11:06) И в че...   Sep 7 2016, 10:20
|- - scifi   Цитата(Integro @ Sep 6 2016, 16:43) Тепер...   Sep 6 2016, 14:07
- - IgorKossak   Granadoespada , соблаговолите оформлять код как по...   Sep 6 2016, 12:18
RSS Текстовая версия Сейчас: 20th August 2025 - 11:55
Страница сгенерированна за 0.01657 секунд с 7
