> МК на температуру < -40º С
war4one
сообщение May 15 2007, 09:12
Из: г. Уфа
Пользователь №: 6 851
Есть ли в природе доставабельные МК на мороз -50º, -60º С? Или это фантастика?
Электронные устройства Open Hardware
doomer#gp
сообщение May 15 2007, 10:56
Из: USA
Пользователь №: 3 234
Есть варианты MPC5553/MPC5554 ( MPC5554AZP132 ) на -55С, на freescale цена $130.17 за штуку при партияк >1000.
Это PowerPC BookE e200, есть FPU, тактовая 132 MHz.
У католожников не меньнше $250
Вот краткое описание:
Freescale’s e200z6 Core
High-performance 132 MHz 32-bit PowerPC Book E-compliant core
Memory management unit (MMU) with 32-entry fully associative translation lookaside buffer (TLB)
SPE (signal processing extension): DSP, SIMD and floating point capabilities
Memory
2 MB of embedded Flash memory with Error Correction Coding (ECC) and Read While Write capability (RWW)
64 KB on-chip static RAM with Error Correction Coding (ECC)
32 KB of cache (with line-locking) that can be configured as additional RAM
System
Two enhanced time processor units (eTPUs) with 64 I/O channels and 19k of designated SRAM
64-channel eDMA (Enhanced Direct Memory Access) controller
Interrupt controller (INTC) capable of handling 286 selectable-priority interrupt sources
Frequency modulated phase-locked loop (FMPLL) to assist in electromagnetic interference (EMI) management
MPC500 compatible External Bus Interface
Nexus IEEE-ISTO 5001™ Class 3+ multicore debug capabilities
5/3.3V IO, 5V ADC, 3.3V/1.8V bus, 1.5V core
416 pin PBGA package
Temperature Range: -40 to 125?C
Optional Temperature Range: -55 to 125?C
I/O
40 channel dual Enhanced queued analog-to-digital converter (eQADC) - up to 12 bit resolution and up to 1.25ms conversions, 6 queues with triggering and DMA support
Four deserial serial peripheral
Interface (DSPI) modules - 16 bits wide up to 6 chip selects each
Three controller area
Network (CAN) modules with 64 buffers each
Two enhanced serial communication
Interface (eSCI) modules
24 channel enhanced multiple I/O system (EMIOS) with unified channels
Еrrata приличная, косяки с programm flash.
war4one
сообщение May 15 2007, 23:37
Из: г. Уфа
Спасибо, некислый проц smile.gif Буду знать, что хоть что-то есть.
Так и не удалось найти МК на замену примерно ATmega32-128, с соответствующей ценой. > +100 - пожалуйста, многие держат, а морозоустойчивого - ничего, даже атмелевские четырехбитки MARC4 - и те только до -40.
Придется делать девайс по старинке - аналоговая схемка решает, надо ли включать подогрев и подавать питание на остальную схему.
RSS Текстовая версия Сейчас: 5th September 2025 - 10:43
Страница сгенерированна за 0.01372 секунд с 7
