> CIC фильтры
feex
сообщение Mar 25 2008, 22:49
Пользователь №: 27 237
всем привет.
нужно какое-нибудь vhdl-описание данных фильтров. кто-нибудь знает, где его можно откопать?
alex_os
сообщение Mar 26 2008, 08:14
Пользователь №: 17 030
Цитата(feex @ Mar 26 2008, 01:49) *
всем привет.
a чего там делать? Один аккумулятор один регистр и один вычитатель?
Типа такого (это интерполятор 3го порядка):
library ieee;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
use work.tx_dvbt.all;
entity CIC_filtr is
port
        reset:   in std_logic;
        clk:     in std_logic;
        in_re:  in std_logic_vector(11 downto 0);
        in_im:  in std_logic_vector(11 downto 0);
        in_ena: in std_logic;
        out_re: out std_logic_vector(15 downto 0);
        out_im: out std_logic_vector(15 downto 0)
end CIC_filtr;
architecture cic_a of CIC_filtr is
     constant P: integer:=3; -- CIC order
     type tWordArray is array (integer range<>) of std_logic_vector(15 downto 0);
     signal dstages_re: tWordArray(0 to P-1);
     signal dstages_im: tWordArray(0 to P-1);
     signal astages_re: tWordArray(0 to P);
     signal astages_im: tWordArray(0 to P);
     signal outd_re:  tWordArray(0 to P);
     signal outd_im:  tWordArray(0 to P);
begin
    G1:
    for k in 0 to P-1 generate
            sub16re_insts:
            sub16 port map
                    aclr => reset,
                    clock => clk,
                    dataa => outd_re(k),
                    datab    => dstages_re(k),
                    result=> outd_re(k+1)
            sub16im_insts:
            sub16 port map
                aclr => reset,
                    clock => clk,
                    dataa => outd_im(k),
                    datab    => dstages_im(k),
                    result=> outd_im(k+1)
            acc16re_insts:
            acc16 port map
                aclr => reset,
                    clock => clk,
                    data=> astages_re(k),
                    result=> astages_re(k+1)
            acc16im_insts:
            acc16 port map
            aclr => reset,
                clock => clk,
                data=> astages_im(k),
                result=> astages_im(k+1)
    end generate G1;
        diff_stages:
        process(clk, reset)
        begin
            if reset='1' then
                for i in 0 to P-1 loop
                    dstages_re(i)<=(others=>'0');
                    dstages_im(i)<=(others=>'0');
        --            astages_re(i)<=(others=>'0');
        --            astages_im(i)<=(others=>'0');
                end loop;
                outd_re(0) <= (others=>'0');
                outd_im(0) <= (others=>'0');
            else
                if in_ena='0' then
                    null;
                elsif rising_edge(clk) then
                    outd_re(0) <= in_re(11)&in_re(11)&in_re(11)&in_re(11)&in_re;
                    outd_im(0) <= in_im(11)&in_im(11)&in_im(11)&in_im(11)&in_im;
                         dstages_re(i) <= outd_re(i);
                         dstages_im(i) <= outd_im(i);
                    end loop;
                end if;
            end if;
        end process;
        astages_re(0) <= outd_re(P) when in_ena='1' else
                                         (others=>'0');
        astages_im(0) <=  outd_im(P) when in_ena='1' else
                                         (others=>'0');
        out_re <= astages_re(P);
        out_im <= astages_im(P);
end architecture cic_a;
ну не художники мы...
RSS Текстовая версия Сейчас: 11th August 2025 - 18:36
Страница сгенерированна за 0.02008 секунд с 7
