> Xilinx eth core implementation error
gosha
сообщение Dec 30 2010, 07:06
Из: Менделеево
Пользователь №: 30
Virtex4, Ise 10.1, Xilinx Core generator.
На стадии map implementation проекта xilinx eth с rgmii выдаются ошибки:
Ни как не могу понять причину, какие ограничения и для каких компонентов надо задать?
Какие доп данные/ фрагменты кода/log нужно/можно привести?
Пропадаю.
QUOTE
Phase 4.2
ERROR:Place:872 - Delay element
"eth23/eth23/v4_emac_block/rgmii_rxd_rising_0_i(0)" has been placed at
ILOGIC_X0Y155 due to the following location constraint on component
"RGMII_RXD_0(0)":
COMP "RGMII_RXD_0(0)" LOCATE = SITE "N21" LEVEL 1
However, the delay controller that calibrates this delay element has not been
used. Please instantiate a delay controller and apply appropriate location
constraint, or instantiate one delay controller for the design with out any
location constraint. Please refer to the usage document to use the controller
efficiently.
"eth23/eth23/v4_emac_block/rgmii_rxd_rising_0_i(1)" has been placed at
ILOGIC_X0Y154 due to the following location constraint on component
"RGMII_RXD_0(1)":
COMP "RGMII_RXD_0(1)" LOCATE = SITE "M21" LEVEL 1
efficiently.
"eth23/eth23/v4_emac_block/rgmii_rxd_rising_0_i(2)" has been placed at
ILOGIC_X0Y153 due to the following location constraint on component
"RGMII_RXD_0(2)":
COMP "RGMII_RXD_0(2)" LOCATE = SITE "N18" LEVEL 1
efficiently.
"eth23/eth23/v4_emac_block/rgmii_rxd_rising_0_i(3)" has been placed at
ILOGIC_X0Y152 due to the following location constraint on component
"RGMII_RXD_0(3)":
COMP "RGMII_RXD_0(3)" LOCATE = SITE "N17" LEVEL 1
efficiently.
ERROR:Place:850 - Delay element
"eth23/eth23/v4_emac_block/rgmii_rxd_rising_1_i(0)" has been placed at
ILOGIC_X1Y103, however, the delay controller that calibrates this element has
not been used. If a delay controller has been instantiated and a location
constraint has been applied to it, please constraint this delay element to
the same region. If a delay controller has not been instantiated please
instantiate one. Please refer to the usage document to use the delay
controller efficiently.
"eth23/eth23/v4_emac_block/rgmii_rxd_rising_1_i(1)" has been placed at
ILOGIC_X1Y102, however, the delay controller that calibrates this element has
"eth23/eth23/v4_emac_block/rgmii_rxd_rising_1_i(2)" has been placed at
ILOGIC_X1Y111, however, the delay controller that calibrates this element has
"eth23/eth23/v4_emac_block/rgmii_rxd_rising_1_i(3)" has been placed at
ILOGIC_X1Y109, however, the delay controller that calibrates this element has
"eth23/eth23/v4_emac_block/rgmii_rx_ctl_rising_0_i" has been placed at
ILOGIC_X0Y148 due to the following location constraint on component
"RGMII_RX_CTL_0":
COMP "RGMII_RX_CTL_0" LOCATE = SITE "R16" LEVEL 1
efficiently.
"eth23/eth23/v4_emac_block/rgmii_rx_ctl_rising_1_i" has been placed at
ILOGIC_X1Y97, however, the delay controller that calibrates this element has
WARNING:Place:851 - The delay controller "eth23/eth23/v4_emac_block/dlyctrl_0"
has been locked with the following location constraint:
COMP "eth23/eth23/v4_emac_block/dlyctrl_0" LOCATE = SITE "IDELAYCTRL_X0Y6"
LEVEL 1
However, none of the delay elements calibrated by this controller are being
used. The controller will still use up a global clock resource from the clock
region and consume power. Please refer to the usage document to use the
WARNING:Place:851 - The delay controller "eth23/eth23/v4_emac_block/dlyctrl_1"
COMP "eth23/eth23/v4_emac_block/dlyctrl_1" LOCATE = SITE "IDELAYCTRL_X0Y1"
LEVEL 1
"eth23/eth23/v4_emac_block/dlyctrl_clk_0" has been locked with the following
COMP "eth23/eth23/v4_emac_block/dlyctrl_clk_0" LOCATE = SITE
"IDELAYCTRL_X1Y5" LEVEL 1
"eth23/eth23/v4_emac_block/dlyctrl_clk_1" has been locked with the following
COMP "eth23/eth23/v4_emac_block/dlyctrl_clk_1" LOCATE = SITE
"IDELAYCTRL_X1Y2" LEVEL 1
CODE
#.ucf
CONFIG PART = 4vfx60ff672-10;
NET "CLK_I" TNM_NET = "CLK_I";
TIMESPEC TS_CLK_I = PERIOD "CLK_I" 125 MHz HIGH 50%;
NET "PCI_CLK" TNM_NET = "PCI_CLK";
TIMESPEC TS_PCI_CLK = PERIOD "PCI_CLK" 35 MHz HIGH 50%;
INST "*v4_emac"           LOC = "EMAC_X0Y0";
# IDELAYCTRL location - must be same clock region as receiver IOs
INST "*dlyctrl_0"        LOC = "IDELAYCTRL_X0Y6";
INST "*dlyctrl_clk_0"    LOC = "IDELAYCTRL_X1Y5";
INST "*dlyctrl_1"        LOC = "IDELAYCTRL_X0Y1";
INST "*dlyctrl_clk_1"    LOC = "IDELAYCTRL_X1Y2"
Прикрепленный файл  example_design.zip ( 49.16 килобайт ) Кол-во скачиваний: 13
RSS Текстовая версия Сейчас: 27th July 2025 - 08:23
Страница сгенерированна за 0.01371 секунд с 7
