> mkernel, новая ртось для ARM
MBR
сообщение Aug 8 2012, 06:47
Пользователь №: 59 748
Долго пытаясь доработать ртоси под свои нужды, понял, что ничего адекватного на рынке просто не существует и решил написать свою. Вот что получилось:
MKernel is embedded RTOS, based on microkernel architecture.
It's designed for ARM microprocessors, however, can be easily ported to any
32bit MCU.
Features:
- BSD License, royalty free, open source.
- Tickless. For system scheduling used 1 HPET timer and RTC. If RTC is
unavailable, another HPET timer can be used for RTC emulation (with full RTC
functionality)
- Hardware abstraction.RTOS is providing common interface for drivers.
- Standart microkernel syncronization: mutexes, events, semaphores, queues.
- Nested mutex priority inheritance
- Embedded dynamic memory manager, with ability of nested memory pools for
threads, dedicated system pool. Aligned malloc calls inside of any pools
- Safe and MPU ready. All supervisor-specific calls are wrapped around
swi/svc calls for context rising.
- Embedded libraries:
* printf/sprintf. Around 1k of code.
* time routines. POSIX-light
* single-linked list, double linked list, ring buffer, block ring buffer
* random number generation: hardware (if supported) or software
- Error handling:
* kill thread on system error, print error, if configured
* restart system on critical error, memory dump if configured
* handle error exceptions, decode address (if supported) and exception code
- Lot of debug features:
* memory dumps
* object marks
* thread profiling: name, uptime, stack allocated/current/used
* memory profiling: red-markings, pool free/allocated size, objects fragmentation
* stack profiling: supervisor allocated/current/used. Plus for arm7 - irq, fiq, abt
* configurable debug console
- Supported hardware:
* ARM7
* cortex-m3, drivers for:STM32 F2 (gpio, uart, rcc, timer, dma, rand)
Cortex-M3 features:
- Native SVC and pendSV support
ARM7 features:
- Nested interrupts
- FIQ support
- pendSV emulation, when returning to user/system context
И сразу из минусов: документация еще пока в стадии разработки, надеюсь, к концу сентября управлюсь. Примеры, надеюсь, на этой неделе будут готовы. На данный момент поддерживается только gcc.
Ссылка на проект на github: https://github.com/alexeyk13/mkernel
Lotor
сообщение Aug 8 2012, 06:56
Пользователь №: 28 866
Можете раскрыть более подробно этот пункт? Чем так Ваша ртос отличается от FreeRTOS, UCOS и других "неадекватных"?
Ковырял чукча отверткой в ухе, звук в телевизоре и пропал.
IgorKossak
сообщение Aug 8 2012, 07:10
Шаман
Из: Киев, Украина
Пользователь №: 221
В папках arch/arm arch/cortex_m3 файлы delay_*.s желательно переименовать в delay_*.S дабы не гневить Eclipse (и ради однообразия тоже).
MBR
сообщение Aug 8 2012, 07:54
В сторону ucos я не смотрел принципиально - там gpl и этот недостаток для эмбеда перевесит все остальное.
Основной недостаток Free rtos, tn-kernel и им подобных, на мой взгляд, - тоже идеологический - это очень сильное абстрагирование от архитектуры, поддержка 8битников и т.п., в результате чего возможности аппаратной части используются не на полную. А из конкретных - различия, практически, по всем пунктам. Особенно, использование системных тиков для шедулера задач. Из плюсов free rtos - безусловно, размер кода (правда, если во free rtos включить все, что есть в mkernel, я сомневаюсь, что получится меньше).
Соглашусь, слово "адекватный", пожалуй, слишком грубо.
Спасибо за совет, сделаю в следующем коммите. Я делал как раз ради различия, чтобы было понятно, что файл обрабатывается препроцессором или нет.
Сообщение отредактировал MBR - Aug 8 2012, 07:55
haker_fox
сообщение Aug 8 2012, 08:27
Познающий...
Из: г. Иркутск
Пользователь №: 8 125
Знаете, чего мне не хватает во встраиваемой РТОС? Правильно наличия драйверов и стеков USB (host & master), ETH, CAN, MMC/SD (и прочих накопителей) под самые разнообразные архитектуры, GUI очень даже приветствуется с наличием драйверов под разные контроллеры и дисплеи, и чтобы гарантированно работало, т.к. собрать это по кускам из Инета дело не очень сложное. Но не заработает сразу.
Да, самое главное. Лицензия должна быть полностью свободная.
З.Ы. Это был крик души. Я реалист когда надо, и понимаю, что я написал утопию)))
Выбор.
MBR
сообщение Aug 8 2012, 09:13
Я двигаюсь именно в эту сторону. Драйверы USB (device, scsi, mass storage), SD-CARD у меня готовы и встроены в mkernel (но не в то, что есть на гитхабе). В добавок есть абстрактный драйвер storage, с конвеером на базе data queue.
Просто на данный момент я не определился с их распространением - если достаточно разовьется идея донаторства, я выложу их в open source, если же нет, буду продавать отдельно.
0.1.2
- added examples for STM32 F2
- optimized software rand
- renamed all .s to .S
в примере создаются две простейшие задачи - одна моргает светодиодом, другая выводит аптайм каждую секунду. Доступна также встроенная отладочная консоль для профайлинга (помощь - h)
Сообщение отредактировал MBR - Aug 8 2012, 09:14
MBR
сообщение Aug 15 2012, 08:34
0.1.3
+ pin keyboard module with debounce logic
! sys_alloc, sys_alloc_aligned, sys_free now supported in SYS context
+ push method for debug console
Приступил к написанию документации. Думаю, к концу сентября будет готово.
haker_fox
сообщение Aug 15 2012, 12:42
Познающий...
Из: г. Иркутск
QUOTE (MBR @ Aug 15 2012, 17:34) *
0.1.3
Выбор.
MBR
сообщение Sep 12 2012, 15:34
Вернулся из отпуска.
0.1.4
+ new module: software timers, running in independent thread
+ keyboard module new functions: keyboard_wait_for_key, keyboard_has_messages
! exception handling improved:
- detection of caller context (SYS/thread), instruction address, caused problem
- if thread context, thread will be terminated, if SYS, system will be restarted
- SVC call while interrupts are disabled error decoded and processed, instead of
general hard fault
- configurable option to halt system on fatal error, instead of rebooting
Также выложена первая версия документации.
_Артём_
сообщение Sep 12 2012, 16:32
Пользователь №: 17 322
Кстати, у меня под Yagarto не собралось...
MBR
сообщение Sep 12 2012, 16:43
Давайте разбираться. Лог? Версия gcc? Я использую codesourcery, как наиболее популярную среду.
_Артём_
сообщение Sep 12 2012, 17:17
Вот такой лог:
p:\Chuzhoj_cod\alexeyk13-mkernel-fc86765\example\stm32f2>make
makefile:94: яЁхфєяЁхцфхэшх: яхЁхюяЁхфхыхэшх ъюьрэф фы  Ўхыш `.s.o'
makefile:89: яЁхфєяЁхцфхэшх: ёЄрЁ√х ъюьрэф√ фы  Ўхыш `.s.o' шуэюЁшЁє■Єё
AS_C: ../../arch/cortex_m3/startup_cortexm.s
In file included from ./../../arch/cortex_m3/startup_cortexm.s:31:0:
../../arch/hw_config.h:41:31: fatal error: hw_config_stm32f2.h: No such file or
directory
compilation terminated.
make: *** [startup_cortexm.o] ╬°шсър 1
Версия:
p:\Chuzhoj_cod\alexeyk13-mkernel-fc86765\example\stm32f2>arm-none-eabi-gcc -v
Using built-in specs.
COLLECT_GCC=arm-none-eabi-gcc
COLLECT_LTO_WRAPPER=c:/yagarto/bin/../libexec/gcc/arm-none-eabi/4.6.2/lto-wrappe
r.exe
Target: arm-none-eabi
Configured with: ../gcc-4.6.2/configure --target=arm-none-eabi --prefix=/home/ya
garto/install --disable-nls --disable-shared --disable-threads --with-gcc --with
-gnu-ld --with-gnu-as --with-dwarf2 --enable-languages=c,c++ --enable-interwork
--enable-multilib --with-newlib --with-headers=../newlib-1.19.0/newlib/libc/incl
ude --disable-libssp --disable-libstdcxx-pch --disable-libmudflap --disable-libg
omp -v
Thread model: single
gcc version 4.6.2 (GCC)
MBR
сообщение Sep 12 2012, 18:13
directory
Собственно, как описано в главе getting started, необходимо скопировать файл hw_config_stm32f2.h из каталога template в рабочий каталог проекта. Путь к нему должен быть прописан в Makefile
Я завтра добавлю его в example. Соглашусь, примеры должны компилироваться без дополнительных настроек.
_Артём_
сообщение Sep 12 2012, 20:21
Нечитал, потому как
Off: как понять вот это:
Хотя бы в общих чертах...
AHTOXA
сообщение Sep 13 2012, 02:35
фанат дивана
Из: Уфа
Пользователь №: 29 684
makefile:94: предупреждение: переопределение команд для цели `.s.o'
makefile:89: предупреждение: старые команды для цели `.s.o' игнорируются
RSS Текстовая версия Сейчас: 26th August 2025 - 14:28
Страница сгенерированна за 0.01484 секунд с 7
