> Где купить Cyclone V плату с наименьшим обвесом?, Где купить Cyclone V плату с наименьшим обвесом?
L47
сообщение Oct 2 2014, 05:49
Пользователь №: 81 793
Здравствуйте, подскажите где можно приобрести плату с cyclone V E с наименьшим обвесом(светодиоды, LCD, память и т.д.) и большим количеством выводов (250+) ?
подобно плате Terasic TREX-S2 TMA
blackfin
сообщение Oct 2 2014, 06:28
Пользователь №: 4 261
С 250+ GPIOs не подскажу, а со 168 есть cubicboard.
L47
сообщение Oct 2 2014, 07:08
168 не хватит,
можно и GX серию, главное чтобы было 250+ выводов.
Maverick
сообщение Oct 2 2014, 07:33
я только учусь...
Из: Украина
Пользователь №: 24 839
Цитата(L47 @ Oct 2 2014, 10:08) *
168 не хватит,
вот нашел
The DBM-SoC1 module provides an easy way to use an Altera Cyclone V-SoC device. The module includes the SoC device, the DDR3 memory, clock distribution, flash memory and the powersupply for all required voltages. The HPS and FPGA signals are available on two 150pin high speed connectors on the back side of the board. Together with all the FPGA signals, the IO-bank supply voltages are available on the two connectors, too. As the Hard-Processor-System (HPS) in the SoC device, provides a variety of peripheral functions like Ethernet, USB, CAN.. - the respective PHYs have to be implemented on the baseboard.
The board requires a 3.3V power supply and generates all the required voltages for the Core, memory and IO using Enpirion PowerSoC devices.
For the interface with the baseboard two Samtec ERM8-075-EGPS connectors are used on the module.
As Altera provides several logic densities in the same footprint, the module will be available from the smallest SoC with 25KLE up to the biggest with 110KLEs.
Customised versions with different memory and flash densities or different temperature or speedgrades are available on request. A base board DBM-SoC-Base1 is available for first tests.
или эта
If it doesn't work in simulation, it won't work on the board.
"Ты живешь в своих поступках, а не в теле. Ты — это твои действия, и нет другого тебя" Антуан де Сент-Экзюпери повесть "Маленький принц"
L47
сообщение Oct 2 2014, 11:07
Цитата(Maverick @ Oct 2 2014, 17:33) *
там мало:
DBM-SoC1 Cyclone V SoC Module:
FPGA Pins:
o 16 Pins IO-Bank 3a
o 32 Pins IO-Bank 3b
o 68 Pins IO-Bank 4a
o 16 Pins IO-Bank 5a
o 10 Pins IO-Bank 8a/5b
RSS Текстовая версия Сейчас: 31st August 2025 - 17:04
Страница сгенерированна за 0.01383 секунд с 7
