> Счетчик нажатия кнопок на LDM-XC3S500E-PQ208 (Spartan 3e), Проект считает количество нажатий и выводит результат на светодиоды
aleshanoff
сообщение Jul 9 2015, 06:01
Из: Смоленск
Пользователь №: 86 484
Здравствуйте. Собираю 4-х разрядный счетчик нажатия кнопки на плате LDM-XC3S500E-PQ208.
Выдает следующую ошибку:
ERROR:Place:1018 - A clock IOB / clock component pair have been found that are not placed at an optimal clock IOB /
clock site pair. The clock component <but1_BUFGP/BUFG> is placed at site <BUFGMUX_X1Y0>. The IO component <but1> is
placed at site <IPAD174>. This will not allow the use of the fast path between the IO and the Clock buffer. If this
sub optimal condition is acceptable for this design, you may use the CLOCK_DEDICATED_ROUTE constraint in the .ucf
file to demote this message to a WARNING and allow your design to continue. However, the use of this override is
highly discouraged as it may lead to very poor timing results. It is recommended that this error condition be
corrected in the design. A list of all the COMP.PINs used in this clock placement rule is listed below. These
examples can be used directly in the .ucf file to override this clock rule.
< NET "but1" CLOCK_DEDICATED_ROUTE = FALSE; >
подскажите, где я ошибся?
- aleshanoff   Счетчик нажатия кнопок на LDM-XC3S500E-PQ208 (Spartan 3e)   Jul 9 2015, 06:01
- - Bad0512   Цитата(aleshanoff @ Jul 9 2015, 12:01) Зд...   Jul 9 2015, 06:30
- - egorman44   Цитата(aleshanoff @ Jul 9 2015, 09:01) Зд...   Jul 9 2015, 06:51
- - Lmx2315   Цитата(aleshanoff @ Jul 9 2015, 10:01) .....   Jul 9 2015, 07:12
|- - Bad0512   Цитата(Lmx2315 @ Jul 9 2015, 13:12) ..вст...   Jul 9 2015, 07:53
|- - Lmx2315   Цитата(Bad0512 @ Jul 9 2015, 11:53) Ошибк...   Jul 9 2015, 08:03
- - aleshanoff   Всем спасибо за такое бурное обсуждение))) Ошибк...   Jul 9 2015, 08:27
|- - Bad0512   Цитата(aleshanoff @ Jul 9 2015, 14:27) Вс...   Jul 9 2015, 08:39
- - aleshanoff   Собрал, работает, считает, но как и предполагалось...   Jul 9 2015, 08:57
|- - iosifk   Цитата(aleshanoff @ Jul 9 2015, 11:57) ст...   Jul 9 2015, 10:43
- - qwa   Цитата(aleshanoff @ Jul 9 2015, 11:57) И ...   Jul 9 2015, 08:59
- - aleshanoff   Особенно не понятна фраза из статьи: "Для это...   Jul 9 2015, 09:00
|- - Amurak   Цитата(aleshanoff @ Jul 9 2015, 12:00) о ...   Jul 9 2015, 09:09
|- - aleshanoff   Цитата(Amurak @ Jul 9 2015, 14:09) О том,...   Jul 9 2015, 09:16
- - Golikov A.   вот вам пример Кодreg knopka_old = 0; reg [7...   Jul 9 2015, 09:56
|- - aleshanoff   Цитата(Golikov A. @ Jul 9 2015, 14:56) во...   Jul 9 2015, 10:07
|- - Jackov   Цитата(aleshanoff @ Jul 9 2015, 13:07) а ...   Jul 9 2015, 16:48
- - Golikov A.   Цитатаа на VHDL можно? или в схематике? я мало что...   Jul 9 2015, 10:26
RSS Текстовая версия Сейчас: 21st August 2025 - 06:06
Страница сгенерированна за 0.01471 секунд с 7
