> Keil Development Suite for ARM - Version 2.00-2.20, Вдруг кому надо...
CrazyAlex
сообщение Jan 31 2005, 12:06
Из: Пермь
Пользователь №: 1 881
Вот кинули на почту, что вышел кейл 2.0.
Список изменений:
[Enhanced Device Simulation and Target Debugging]
Added device simulation and target debugging for the following devices:
Atmel AT91SAM7S128, AT91SAM7S256, AT91SAM7S32, AT91SAM7S64. Projects for Atmel AT91SAM7S Evaluation Board are included in the folder ..\ARM\...\Boards\Atmel\AT91SAM7S.
Philips LPC2131, LPC2132, LPC2138. Projects for Keil MCB2130 Evaluation Board are included in the folder ..\ARM\...\Boards\Keil\MCB2130.
[ULINK - Enhancements + New Features]
Corrected: problem with Big Endian interpretation on Samsung devices (configuration example in GNU\Boards\Samsung\S3C340X).
Added: Philips LPC213x and LPC210x devices are now stopped at RESET. There are no longer issues with lock situations (for example IDLE mode) that disable JTAG.
[Device Support]
Added startup code, example project, and header files for Samsung S3C44B0X (folder ..\ARM\Boards\Samsung\S3C44001\Hello).
Enhanced example projects with configuration for external program memory on Philips LPC2200 (folder ..\ARM\..\Boards\Phytec).
[Keil CARM Compiler]
The Keil CARM Compiler is included as final release. Added is a PACK directive and the __packed attribute that allows definition of byte-aligned variables.
[Keil AARM Macro Assembler]
Corrected: problem with LDR PC,=Reset_Addr (should load address, but not content). Note: check your Startup.S files, since it was part of the startup code in early versions.
[LA Linker/Locater]
Added: ELF/DWARF output file. The linker now generates an ELF/DWARF compatible output file with the extension *.ELF.
[µVision Debugger]
Enhanced: The ELF/DWARF loader has been enhanced and performs now full stack tracking, contains display support for enum types, uses the life-time information for register variables and allows debugging of source code in include files.
[Advanced RTX Real-Time Operating System]
Added: Advanced RTX Kernel including Kernel aware debugging support is now part of the Keil Development Suite for ARM.
Качать можно отсюда: http://www.keil.com/demo/eval/arm.htm
- CrazyAlex   Keil Development Suite for ARM - Version 2.00-2.20   Jan 31 2005, 12:06
- - VAI   Заливаю. Кто может протестьть и сравнить с ИАРом?   Jan 31 2005, 14:33
- - NickB   Цитата(VAI @ Jan 31 2005, 17:33)Заливаю. Кто ...   Feb 1 2005, 08:13
|- - CrazyAlex   Цитата(NickB @ Feb 1 2005, 14:13)Чего еще хор...   Feb 11 2005, 08:56
- - CrazyAlex   Вышел в свет кейл 2.11 для ARM. Список изменений в...   Mar 22 2005, 08:12
|- - AjaxLab   Цитата(CrazyAlex @ Mar 22 2005, 11:12)Вышел в...   Mar 23 2005, 13:32
|- - CrazyAlex   Цитата(AjaxLab @ Mar 23 2005, 19:32)А если не...   Apr 28 2005, 03:34
- - SergM   Дополню CrazyAlex: В сообщении от Keil Software S...   Mar 22 2005, 08:37
- - CrazyAlex   Вышел в свет кейл 2.20 для ARM. >Keil CARM Ver...   Apr 28 2005, 03:41
- - IgorKossak   Глядя на такую частоту возникновения релизов невол...   Apr 28 2005, 07:52
- - igor-k   А в ентой Keil не знают про AT91RM9200. Или я прос...   Apr 30 2005, 04:25
|- - yuriyc   Цитата(igor-k @ Apr 30 2005, 07:25)А в е...   May 4 2005, 16:41
- - mu-bart   помогите, жизненно нужна переведённая техническая ...   Mar 17 2006, 11:40
- - Tcom   Смотри www.gaw.ru пощёлкай там есть перевод   Jan 2 2008, 09:17
- - VAI   Tcom Вы заметили дату сообщения на которое отвечал...   Jan 2 2008, 13:21
|- - Konst_777   Цитата(VAI @ Jan 2 2008, 17:21) Tcom Вы з...   Jan 2 2008, 18:41
- - VAI   человек задал вопрос совсем в другой теме, это его...   Jan 3 2008, 08:05
RSS Текстовая версия Сейчас: 22nd August 2025 - 22:47
Страница сгенерированна за 0.01364 секунд с 7
