> Ошибка при поднятии нетлиста
romanp
сообщение May 11 2009, 15:47
Из: Хайфы
Пользователь №: 9 689
ERROR: Unable to reserve cell partition CellDB in library U:\BIG\Work_Board\SSB\PCB\Work\Layout_Temp\Design.llm
ERROR: Unable to create local Cell Library.
DataBase Load is being terminated with 2 errors and 0 warnings.
Logic Data has NOT been Compiled.
Помогите исправить
fill
сообщение May 26 2009, 07:02
Из: КП Две Поляны
Пользователь №: 512
Помогите исправить
Воспользуйтесь поиском по базе знаний ментора - например из найденного:
Unable to reserve cell partition CellDB..." during Forward Annotation may be due to corrupted Design.llm and CellDB.cel files.
1. Make a backup of the whole project.
2. Create a new PCB job and Forward Annotate.
3. Copy the new Layout\Design.llm and Layout\CellDB.cell files to the original job's Layout folder, overwriting the existing files.
4. Delete the contents of the Work folder for the original Job.
5. Open the design in Expedition PCB and Forward Annotate.
или
Causes
* Local design.llm and cell library were corrupt.
Solution
Create an empty PCB design and copy the design.llm and the celldb.cel files from the empty job layout subdirectory to the problem job's layout subdirectory.
Note: All local cell editor changes will be lost and will need to be recreated.
Exit the design and delete the PCB\Layout\SysIndex.cbf file to rebuild the corrupt Design.LLM file.
www.megratec.ru
RSS Текстовая версия Сейчас: 2nd September 2025 - 17:17
Страница сгенерированна за 0.01339 секунд с 7
