real time timer - прерывание по переполнению |
May 26 2010, 16:10
Из: Пермь
Пользователь №: 54 501
aaarrr, ок. спасибо за желание помочь. CODE template <uint_t i_timer> class CTimerImpl { private: static const AT91PS_TC m_timer; static const uint_t m_timer_id = i_timer == 0 ? AT91C_ID_TC0 : i_timer == 1 ? AT91C_ID_TC1 : i_timer == 2 ? AT91C_ID_TC2 : 0;
private: static const uint32_t m_max_ticks = 0x10000; static const uint32_t m_interrupt_priority = 1;
public: static CTimerImpl<i_timer>* m_instance;
private: float m_max_time_ms; float m_ticks_per_ms;
private: static void interrupt_handler() { uint32_t mask = m_timer->TC_SR; uint32_t x = 0; x = mask; // m_instance->on_interrupt(mask); }
inline bool on_interrupt(uint32_t mask) { if (mask & AT91C_TC_CPAS) on_event_a(); if (mask & AT91C_TC_CPBS) on_event_b(); if (mask & AT91C_TC_CPCS) on_overflow();
return (mask & (AT91C_TC_CPAS | AT91C_TC_CPCS | AT91C_TC_CPBS)) != 0; }
uint32_t calculate_optimal_divider(float max_period_ms) { const float cycles_per_ms = CSystem::get_instance()->get_frequency() / 1000.0f; const float max_time_ms = m_max_ticks / cycles_per_ms;
m_max_time_ms = max_time_ms * 2.0f; m_ticks_per_ms = cycles_per_ms / 2.0f;
if (m_max_time_ms > max_period_ms) return AT91C_TC_CLKS_TIMER_DIV1_CLOCK;
m_max_time_ms = max_time_ms * 8.0f; m_ticks_per_ms = cycles_per_ms / 8.0f;
if (m_max_time_ms > max_period_ms) return AT91C_TC_CLKS_TIMER_DIV2_CLOCK;
m_max_time_ms = max_time_ms * 32.0f; m_ticks_per_ms = cycles_per_ms / 32.0f;
if (m_max_time_ms > max_period_ms) return AT91C_TC_CLKS_TIMER_DIV3_CLOCK;
m_max_time_ms = max_time_ms * 128.0f; m_ticks_per_ms = cycles_per_ms / 128.0f;
if (m_max_time_ms > max_period_ms) return AT91C_TC_CLKS_TIMER_DIV4_CLOCK;
m_max_time_ms = max_time_ms * 1024.0f; m_ticks_per_ms = cycles_per_ms / 1024.0f;
if (m_max_time_ms > max_period_ms) return AT91C_TC_CLKS_TIMER_DIV5_CLOCK;
__STL_THROW(invalid_argument("vary big period")); return AT91C_TC_CLKS_TIMER_DIV5_CLOCK; }
protected: virtual void on_event_a() = 0; virtual void on_event_b() = 0; virtual void on_overflow() = 0;
void initialize(float max_time_ms) { m_instance = this;
AT91F_AIC_CfgPMC(); AT91F_PMC_EnablePeriphClock(AT91C_BASE_PMC, 1 << m_timer_id);
// Disable TC clock m_timer->TC_CCR = AT91C_TC_CLKDIS; AT91F_TC_InterruptDisable(m_timer, 0xFFFFFFFF);
// Clear status register uint32_t mask = m_timer->TC_SR; mask = ~mask;
// Set mode m_timer->TC_CMR = calculate_optimal_divider(max_time_ms) | AT91C_TC_WAVESEL_UP_AUTO | AT91C_TC_WAVE | AT91C_TC_EEVT_XC0;
// enable interrupts AT91F_TC_InterruptEnable(m_timer, AT91C_TC_CPCS | AT91C_TC_CPAS | AT91C_TC_CPBS);
// configure interrupt handler AT91F_AIC_ConfigureIt( AT91C_BASE_AIC, m_timer_id, m_interrupt_priority, AT91C_AIC_SRCTYPE_INT_HIGH_LEVEL, (void(*)())interrupt_handler );
// enable interrupt AT91F_AIC_EnableIt(AT91C_BASE_AIC, m_timer_id); }
void deinitialize() { stop();
// disable interrupts AT91F_TC_InterruptDisable(m_timer, AT91C_TC_CPCS | AT91C_TC_CPAS | AT91C_TC_CPBS);
// mode m_timer->TC_CMR = 0;
// perepheral clock AT91F_PMC_DisablePeriphClock(AT91C_BASE_PMC, 1 << m_timer_id); }
void set_time_a(float time_a_ms) { m_timer->TC_RA = (uint32_t)(std_math::min(time_a_ms, m_max_time_ms) * m_ticks_per_ms); }
void set_time_b(float time_b_ms) { m_timer->TC_RB = (uint32_t)(std_math::min(time_b_ms, m_max_time_ms) * m_ticks_per_ms); }
void set_time_reset(float period_ms) { m_timer->TC_RC = (uint32_t)(std_math::min(period_ms, m_max_time_ms) * m_ticks_per_ms); }
inline void start() { m_timer->TC_CCR = AT91C_TC_CLKEN | AT91C_TC_SWTRG; }
inline void stop() { m_timer->TC_CCR = AT91C_TC_CLKDIS; } };
template <> const AT91PS_TC CTimerImpl<0>::m_timer = AT91C_BASE_TC0;
template <> const AT91PS_TC CTimerImpl<1>::m_timer = AT91C_BASE_TC1;
template <> const AT91PS_TC CTimerImpl<2>::m_timer = AT91C_BASE_TC2;
template <uint_t i_timer> CTimerImpl<i_timer>* CTimerImpl<i_timer>::m_instance; вызываю так: Код CTimer<0> timer(10.0f);
timer.set_time_a(2.0f); timer.set_time_b(6.0f); timer.set_time_reset(8.0f);
timer.start();
while(1);
Сообщение отредактировал aaarrr - May 26 2010, 16:16
Причина редактирования: Оформление цитаты исходника
May 26 2010, 19:16
Из: Пермь
в симуляторе Keil всё пучком максимально упростил код. кому не лень, пожалуйста, скомпилируйте у себя и посмотрите чему равен mask. может у меня контроллер косячный... Код void timer_handler() { unsigned int mask = AT91C_BASE_TC0->TC_SR; mask ++; }
int main() { // enable PMC AT91C_BASE_PMC->PMC_PCER = 1 << AT91C_ID_FIQ; AT91C_BASE_PMC->PMC_PCER = 1 << AT91C_ID_TC0;
// set mode AT91C_BASE_TC0->TC_CCR = AT91C_TC_CLKDIS; AT91C_BASE_TC0->TC_IDR = 0xFFFFFFFF; AT91C_BASE_TC0->TC_SR; AT91C_BASE_TC0->TC_CMR = AT91C_TC_CLKS_TIMER_DIV5_CLOCK | AT91C_TC_WAVESEL_UP_AUTO | AT91C_TC_WAVE | AT91C_TC_EEVT_XC0;
// enable interrupts on compare A, B, C AT91C_BASE_TC0->TC_IER = AT91C_TC_CPAS | AT91C_TC_CPBS | AT91C_TC_CPCS; AT91C_BASE_TC0->TC_RA = 100; AT91C_BASE_TC0->TC_RB = 200; AT91C_BASE_TC0->TC_RC = 400;
// start AT91C_BASE_TC0->TC_CCR = AT91C_TC_CLKEN | AT91C_TC_SWTRG;
// set irq handler AT91C_BASE_AIC->AIC_IDCR = 1 << AT91C_ID_TC0; AT91C_BASE_AIC->AIC_SMR[AT91C_ID_TC0] = 0; AT91C_BASE_AIC->AIC_SVR[AT91C_ID_TC0] = (unsigned int)timer_handler; AT91C_BASE_AIC->AIC_ICCR = 1 << AT91C_ID_TC0;
// enable interrupts from timer AT91C_BASE_AIC->AIC_IECR = 1 << AT91C_ID_TC0;
while (1); }
Сообщение отредактировал srm - May 26 2010, 19:23
May 27 2010, 16:35
Из: Пермь
Вроде, немного разобрался. Если поставить значение делителя 1024 и значения регистров A ~ 10000, B ~ 40000, C ~ 60000, то ошибка перестаёт повторяться. Я несколько изменил тестовый пример. в обработчике делаю так: Код volatile static int ss;
void timer_handler() { unsigned int mask = AT91C_BASE_TC0->TC_SR; ss = (mask & (AT91C_TC_CPAS | AT91C_TC_CPBS | AT91C_TC_CPCS)) == (AT91C_TC_CPAS | AT91C_TC_CPBS); } А в программе постоянно вывожу значение ss: Код while (1) { printf("%d", ss); } Если делитель = 32, A = 0x7331, B = 0xA681, С = 0xD335. Т.о. Время между двумя сравнениями 13136*32/48000 = 8,75 мс. печатается: 00000100001000001000000100000100000100000010000010000010000010000010000001000001 0000010000010000001000001000001 ну не может прерывание обрабатываться 8 миллисекунд! тем более, что при уменьшении времени (вплодь до десятых долей мс) выводится примерно то же самое.
Jun 1 2010, 18:14
Из: Пермь
В реалтайме, вроде, всё норм. У меня 12 сервомеханизмов, шимы под них генерирует таймер at91sam7s256. Всё замечательно, сервы крутятся именно так, как мне нужно. Но, опять всплыл подводный камень и опять с real time timer'ом. если я в цикле изменяю позицию серв: Код while (true) { for (uint32_t x = 0; x < 20000; x ++) { servo0.set_position(servo::min_position + x * (servo::max_position - servo::min_position) / 20000.0f); servo2.set_position(servo::min_position + x * (servo::max_position - servo::min_position) / 20000.0f); // ... servo11.set_position(servo::min_position + x * (servo::max_position - servo::min_position) / 20000.0f); }
for (uint32_t x = 0; x < 20000; x ++) { servo0.set_position(servo::max_position - x * (servo::max_position - servo::min_position) / 20000.0f); servo2.set_position(servo::max_position - x * (servo::max_position - servo::min_position) / 20000.0f); // ... servo11.set_position(servo::max_position - x * (servo::max_position - servo::min_position) / 20000.0f); } } , то всё прекрасно. Если я синхронизирую позицию по таймеру, то сервы время от времени начинают уезжать. т.е. двигается медленно, с постоянной скоростью в одну сторону, потом раз - и резко ушла в другую, потом снова медленно двигается вперёд. повторяется, примерно, один раз за 4 прохода цикла (20 сек): Код while (true) { start_time = watch->get_time_us(); while (true) { uint64_t current_time = watch->get_time_us(); if (current_time - start_time > 5000000) break; float x = (current_time - start_time) / 5000000.0f; servo0.set_position(servo::min_position + x * (servo::max_position - servo::min_position)); }
start_time = watch->get_time_us(); while (true) { uint64_t current_time = watch->get_time_us(); if (current_time - start_time > 5000000) break; float x = (current_time - start_time) / 5000000.0f; servo0.set_position(servo::max_position - x * (servo::max_position - servo::min_position)); } }
Сообщение отредактировал srm - Jun 1 2010, 18:19
Jun 1 2010, 19:14
Из: Пермь
aaarrr, я, вроде, по применению и использую. насколько я понял из даташита, real time timer служит как раз для получения информации о текущем времени. Тем более, что большая точность мне не нужна. Время мне нужно для того, чтобы движения робота были синхронны. Ну и плюс для работы ПИД регуляторов. get_time_us всего лишь запрашивает показание счётчика и переводит тики в микросекунды. По ходу дела, все эти глюки происходят из-за jtag'a. если запускать программу на выполнение без отладки, при отключенном Jtag'е, то глюки, вроде, не повторяются.. В общем, magic!
Сообщение отредактировал srm - Jun 1 2010, 19:18
Jun 25 2010, 07:47
Группа: Validating
Из: Днепропетровск
Пользователь №: 43 367
Добрый день. Дабы не плодить похожих тем решил спросить здесь. Пытаюсь вызвать прерывание от RTTC. Работаю в Keil. Инициализирую так: Код AT91S_AIC *pAIC = AT91C_BASE_AIC; void INIT_RTTC (int Alarm_Value_seconds) { /* Initialize Real Time Timer */ pRTTC->RTTC_RTAR = (Alarm_Value_seconds - 1); pAIC->AIC_IECR = AT91C_ID_SYS; pAIC->AIC_SMR[1] = AT91C_AIC_PRIOR_HIGHEST | AT91C_AIC_SRCTYPE_POSITIVE_EDGE; pRTTC->RTTC_RTMR = (AT91C_RTTC_RTPRES & 0x8000) | AT91C_RTTC_ALMIEN | AT91C_RTTC_RTTRST; } Обработчик объявляю так: Код __irq void RTTC_Interrupt_Handler (void) {
if ((pRTTC->RTTC_RTSR & AT91C_RTTC_ALMS) != 0) { LED_ON; } else { LED_OFF; }
} В стартапе этот кусок поменял так: Код Reset_Addr DCD Reset_Handler Undef_Addr DCD Undef_Handler SWI_Addr DCD SWI_Handler PAbt_Addr DCD PAbt_Handler DAbt_Addr DCD DAbt_Handler DCD 0 ; Reserved Address IRQ_Addr DCD IRQ_Handler FIQ_Addr DCD FIQ_Handler
Undef_Handler B Undef_Handler SWI_Handler B SWI_Handler PAbt_Handler B PAbt_Handler DAbt_Handler B DAbt_Handler PRESERVE8 IMPORT RTTC_Interrupt_Handler IRQ_Handler B RTTC_Interrupt_Handler FIQ_Handler B FIQ_Handler В общем, прерывание не происходит. В чем ошибка, подскажите, пожалуйста. P.S. Отладчиком смотрю содержимое регистра RTT_SR - флаги ALMS и RTCINC -поднимаются и SYSIRQ - находится в состоянии pending. Однако, перехода по вектору не происходит...
Сообщение отредактировал Nikitoc - Jun 25 2010, 08:29
Jun 25 2010, 08:46
Пользователь №: 1 448
Цитата(Nikitoc @ Jun 25 2010, 11:47)  Код AT91C_AIC_SRCTYPE_POSITIVE_EDGE Ну почему, почему все упорно пытаются работать по фронту, а? Для внутренних источников это в 99.9% случаев не нужно, для внешних - в 90%. В остальных 0.1% и 10% нужно проявлять предельную внимательность при обслуживании такого прерывания. В вашем случае отсутствует сброс источника в AIC, и запись в EOICR (хотя если принять во внимание переделку в стартапе, последнее уже несущественно). А уж прерывания RTT - это просто одно большое недоразумение. Для их использования нужно иметь ну очень веские основания.
Jun 25 2010, 09:07
Группа: Validating
Из: Днепропетровск
Цитата(aaarrr @ Jun 25 2010, 11:46)  Ну почему, почему все упорно пытаются работать по фронту, а? Для внутренних источников это в 99.9% случаев не нужно, для внешних - в 90%. В остальных 0.1% и 10% нужно проявлять предельную внимательность при обслуживании такого прерывания. В вашем случае отсутствует сброс источника в AIC, и запись в EOICR (хотя если принять во внимание переделку в стартапе, последнее уже несущественно).
А уж прерывания RTT - это просто одно большое недоразумение. Для их использования нужно иметь ну очень веские основания. Изменил инициализацию таким образом: void INIT_RTTC (int Alarm_Value_seconds) { /* Initialize Real Time Timer */ pRTTC->RTTC_RTAR = (Alarm_Value_seconds - 1); pAIC->AIC_IECR = AT91C_ID_SYS; pAIC->AIC_SMR[1] = AT91C_AIC_PRIOR_HIGHEST; pAIC->AIC_ICCR = AT91C_ID_SYS; pRTTC->RTTC_RTMR = (AT91C_RTTC_RTPRES & 0x8000) | AT91C_RTTC_ALMIEN | AT91C_RTTC_RTTRST; А обработчик так: __irq void RTTC_Interrupt_Handler (void) { if ((pRTTC->RTTC_RTSR & AT91C_RTTC_ALMS) != 0) { LED_ON; } else { LED_OFF; } pAIC->AIC_EOICR = 0; // Reset AIC logic} Все равно не заходит!
Сообщение отредактировал Nikitoc - Jun 25 2010, 09:17
Jun 25 2010, 09:20
Цитата(Nikitoc @ Jun 25 2010, 13:07)  Изменил инициализацию таким образом: ICCR работает только для прерываний по фронту, писать его здесь бессмысленно. Цитата(Nikitoc @ Jun 25 2010, 13:07)  А обработчик так: EOICR нужно писать в любом случае, если уж оказались в прерывании, а не по каким-либо еще условиям. Глобально прерывания разрешены? Отладчик малину не портит, часом?
