> Кит на STM32, Интересный кит.
at90
сообщение Jul 3 2010, 09:37
Из: Краснодар
Пользователь №: 3 814
Набрел на интересную штуковину.
DSO201 is a pocket size digital storage oscilloscope fulfills basic electronic engineering requirements. It is base on ARMCortex™-M3compatible 32 bit platform, equipped with 320*240 color display, SD card capability, USB connection, and chargeable batteries. Weighs only 60g!Portable Digital Oscilloscope DIY Kit provides waveform viewing, pocket size and over 2 hoursbatteryoperation. This DIY kit is a open source code. The Schematic, PCB layout and program code is free for re-design. It is ideal for production test, research, design and education.
Upgrade by bootloader via USB
Power supply 3.7V Chargeable Lithium battery / USB
Dimension (w/o probe) 106mm X 55mm X 9.9mm
http://www.wide.hk/pdf/ARM_DSO_M.pdf
Купить можно тут
http://www.wide.hk/products.php?product=AR...l-Oscilloscope#
или на Ebay.
Облегчу поиски сорцев.
Sources Codes
<<Первая производная от чужой идеи - уже твоя идея.>>
RSS Текстовая версия Сейчас: 20th August 2025 - 15:53
Страница сгенерированна за 0.01347 секунд с 7
