26 страниц V  « < 5 6 7 8 9 > »
> Вопросы по Agilent ADS
kisa_323
сообщение Mar 12 2013, 00:07
Сообщение #91
Пользователь №: 75 645
ads_2012_08_hf2 (General Hotfix)
Installation Instructions (.pdf) Download 945,574 bytes (923,4 kB)
Linux (.zip) Download 560,753,901 bytes (534,8 MB)
Release Notes (pdf) Download 56,950 bytes (55,6 kB)
Windows (.zip) Download 182,218,281 bytes (173,8 MB)
Issues addressed in this hotfix:
Selecting/deselecting objects in ADS2011.05 layout
Shift select should unselect a previously selected vertex
Version Control function update_all_files_in_path() is not refreshing open views.
Version Control: Delete Workspace menu needs to inform SOS that a workspace is being deleted so that SOS can check for checked out items within the workspace
Version Control: Need new interface function so ADS can tell SOS when a workspace is opened and closed
Layer Preferences empty
Layers in the Layers Window and Layers Preferences window are not shown
Agilent Survey Link is broken on WinXP 32-bit
Gerber Import: drill files do not properly handle decimals
IFF export is truncating most angles to an integer number of degrees
IFF import is ignoring library resolution setting and using default resolution
IFF import creates layout views without support for rotation, even if instances are rotated
CouplerDual has bad noise behavior at some coupling values
Design Kit part fails to tune when series component is added.
S4P_Eqn does not work in S-parameters noise simulation when it is terminated withTerm in all ports of the S4P_Eqn
Circuit converges easily on 2011, fails totally on 2012
Allow ADS_Diode data file to be stored at other than workspace ./data location (e.g., with the Design Kits).
Dynamic tuning is not working with subcircuit parameters when linear collapse is enabled
ADS hicum model with NQS turned on is slow and difficult to converge in HB simulation
Tuning produces incorrect results for S-parameter analysis with mixer
SI/PI analyzer does not label nodes correctly yielding to failure of inclusion of parts
Momentum versus FEM different treatment for the via
Momentum Virtuoso cannot invoke the Cadence Distributed Process window in IC615 ISR12 and later
Replace EM_Class_wrk in next ADS hotfix
Disappearing tabs in mailLVS Results Viewer
LVS Results viewing window: tabs for Component mismatches, Nodal mismatches, and Parameter mismatches are lost on repeated viewing
Replace modify "Sample Board setting using Strips" option in ADFI EESOF Export set up
ser_aleksey_p
сообщение Mar 12 2013, 15:46
Сообщение #92
Из: Rybinsk
Пользователь №: 58 593
И где же они, хотфиксы?
1lliivv1
сообщение Apr 4 2013, 10:59
Сообщение #93
Пользователь №: 55 996
А реально ли сделать в Schematic систему для оформления электрических схем по ГОСТу ? Кто-нибудь пробовал что-то подобное? Или даже не стоит заморачиваться с этим в ADS ?
angslv
сообщение May 13 2013, 11:00
Сообщение #94
Из: Zelenograd
Пользователь №: 72 797
Довольно часто в теме звучит вопрос "с чего начать?". Можно поискать Agilent ADS circuit cookbook (мне гугл выдал второй ссылкой то, что надо). В книге доступно и пошагово расписано как в среде ADS возможно создавать те или иные проекты.
Думаю это неплохая отправная точка.
ser_aleksey_p
сообщение May 16 2013, 16:12
Сообщение #95
Из: Rybinsk
Даже и не думайте.
Виталий_
сообщение May 18 2013, 20:24
Сообщение #96
Пользователь №: 71 963
Можно ли ADS прочитать формат s2p? Если можно, то как это сделать?
1lliivv1
сообщение May 19 2013, 04:26
Сообщение #97
Виталий
Да, можно. Нужно использовать элемент S2P на палитре Data Items.
Artemij14
сообщение May 26 2013, 12:12
Сообщение #98
Пользователь №: 58 537
Привет всем!
Моделирую линию задержки, которая состоит из меандра и по краям диэлектрики. Выглядит как на рисунке.
Проблема в том, что когда создаю substrate и указываю в качестве слоя диэлектрика свой материал, а в качестве bunding layer слой в котором находятся полигоны, на месте которых должны быть диэлектрики, весь слой над печатной становится диэлектриком, а не в определенных местах. Т.е. bounding layer игнорируется.
Одним из решений было создать диэлектрические via и тогда уже можно считать с помощью FEM. Но это долго и излишне для моей задачи. А Momentum диэлектрические переходные отверстия не считает.
Почему bounding layer игнорируется? Делал в этом слое структуры и полигоны и линии, и все равно получаю сплошной слой над всей поверхностью платы...
Pir0texnik
сообщение May 27 2013, 02:29
Сообщение #99
Пользователь №: 20 539
Терзают меня смутные сомнения, что моментум позволяет считать подобные 3Д структуры... Металлические виа и 3д диэлектрики - это как бы 2 большие разницы, так что возможно без фема никак.
Artemij14
сообщение May 27 2013, 04:57
Сообщение #100
А зачем тогда bounding area layer? Мне все таки кажется, что по крайней мере наличие и отсутствие в некоторых областях диэлектрика организовать можно и считаться будет. Вопрос в том, почему bounding area layer никак не ограничивает зону где есть диэлектрик.
nadie
сообщение May 27 2013, 15:42
Сообщение #101
Пользователь №: 7 016
ADS2012.08 должен считать подобное в принципе, так как он позволяет задавать разные параметры диэлетрика для различных областей в одном слое (это одно из ново-введений ADS2012.08) Как это делается конкретно надо копать примеры, в моей практике это мне не было нужно
Pir0texnik
сообщение May 28 2013, 00:36
Сообщение #102
Ну тогда вопрос к Артемию, какая версия адс?
ser_aleksey_p
сообщение May 29 2013, 14:44
Сообщение #103
Из: Rybinsk
Именно так!
Моментум считает только металлизированные отверстия.
Диэлектрические отверстия - уже FЕМ.
Artemij14
сообщение Jun 11 2013, 20:09
Сообщение #104
Цитата(ser_aleksey_p @ May 29 2013, 18:44) *
Именно так!
Где б его взять ADS2012...
У меня ADS2011.10. Именно так и приходится выкручиваться! Использовать FEM. А хотелось бы использовать моментум, но почему то там не задается область где есть диэлектрик, а где его нет. Естественно, для задач решаемых в моментуме диэлектрические виа задавать бессмысленно. Читайте мой первый пост.
Спасибо всем за ответы!
Сообщение отредактировал Artemij14 - Jun 11 2013, 20:12
Pir0texnik
сообщение Jun 19 2013, 01:48
Сообщение #105
Гуру, адс 2012, подскажите как, блин, в нем оптимизировать лейаут?
Рисую схематику, оптимизирую ее, генерю по ней лейаут, получаю слегка изменившиеся характеристики, хочу их поправить - отоптимизировать его - КАК ЭТО СДЕЛАТЬ?? Все бубны уже перепробовал, ничего не могу сообразить как влезть в эту железобетонную связь схематики и лейатута....
Пытаюсь делать по алгоритму: создал еще одну схематику с описанием переменных и добавленным оптимизационным компонентом, добавил мой горе-лейаут, как subcircuit (сгенерил предварительно символ и указал, чтобы использовал ЕМ-симуляцию). При запуске оптимизатора - ниче не происходит, изменения внешних переменных никак не сказывается на подцепи...
Пробовал в лейауте добавлять параметры, такие же как и переменные, но это не катит, т.к. оказывается , что они дублируются с параметрами схематики и сыпятся ошибки.... Чего делать? Спасибо!
RSS Текстовая версия Сейчас: 23rd August 2025 - 13:40
Страница сгенерированна за 0.01483 секунд с 7
