> Как согласовать два клоковых региона в ПЛИС
Alexsandr000
сообщение Mar 4 2014, 11:39
Пользователь №: 74 054
Уважаемые форумчане!
Есть ПЛИС Spartan - 6, в проекте возникла ошибка:
Place:1355 - Component < MDO/MCD/blk00003926 > is driven by DCM or PLL
   component < MCM/pll_base_inst/PLL_ADV > placed at < PLL_ADV_X0Y2 >. This
   requires the load component to be range constrained to CLOCKREGION_X0Y5 or
   CLOCKREGION_X1Y5. Placer was not able to apply this range constraint because
   component < MDO/MCD/blk00003926 > has a LOC constraint or area group in a
   different clock region. Please check whether the user constraints and remove
   any conflicting LOCs or area groups. Note that the loads of a DCM/PLL must be
   constrained to the two adjacent clock regions to the DCM/PLL. Using DCM/PLL
   clocks to drive clock pins directly is not a recommended practice. Using a
   BUFG will give more flexibility to the placer and produce superior placement
   results.
Я так понимаю, что надо согласовать клоковые регионы, однако я пока не понимаю как=)))
- Alexsandr000   Как согласовать два клоковых региона в ПЛИС   Mar 4 2014, 11:39
- - o_khavin   Цитата(Alexsandr000 @ Mar 4 2014, 15:39) ...   Mar 4 2014, 11:50
|- - Alexsandr000   Цитата(o_khavin @ Mar 4 2014, 15:50) Не с...   Mar 4 2014, 17:43
|- - o_khavin   Цитата(Alexsandr000 @ Mar 4 2014, 21:43) ...   Mar 4 2014, 17:52
|- - Dmitriyspb   Цитата(o_khavin @ Mar 4 2014, 21:52) Поло...   Mar 5 2014, 06:28
|- - Alexsandr000   Цитата(Dmitriyspb @ Mar 5 2014, 10:28) По...   Mar 5 2014, 13:27
|- - Maverick   Цитата(Alexsandr000 @ Mar 5 2014, 15:27) ...   Mar 5 2014, 13:53
|- - o_khavin   Цитата(Alexsandr000 @ Mar 5 2014, 17:27) ...   Mar 5 2014, 16:13
|- - Dmitriyspb   Цитата(Alexsandr000 @ Mar 5 2014, 17:27) ...   Mar 6 2014, 05:55
|- - olegras   Цитата(Dmitriyspb @ Mar 6 2014, 10:55) Кс...   Mar 6 2014, 13:20
|- - gibson1980   Цитата(olegras @ Mar 6 2014, 21:20) Совет...   Mar 6 2014, 15:06
||- - olegras   Цитата(gibson1980 @ Mar 6 2014, 20:06) А ...   Mar 6 2014, 15:29
|- - Dmitriyspb   Цитата(olegras @ Mar 6 2014, 17:20) Не со...   Mar 7 2014, 06:19
- - Alexsandr000   В принципе это первый такого рода проект, вообще т...   Mar 9 2014, 14:09
|- - olegras   Цитата(Alexsandr000 @ Mar 9 2014, 19:09) ...   Mar 10 2014, 04:35
|- - Alexsandr000   Цитата(olegras @ Mar 10 2014, 08:35) Так-...   Mar 10 2014, 09:14
|- - olegras   Цитата(Alexsandr000 @ Mar 10 2014, 14:14)...   Mar 11 2014, 01:51
|- - Dmitriyspb   Цитата(Alexsandr000 @ Mar 10 2014, 13:14)...   Mar 11 2014, 07:23
- - Alexsandr000   Кодlibrary IEEE; use IEEE.STD_LOGIC_1164.ALL; libr...   Mar 12 2014, 03:03
- - Alexsandr000   Добавил BUFG вроде все заработало) Спасибо за подс...   Mar 12 2014, 05:14
- - olegras   Цитата(Alexsandr000 @ Mar 12 2014, 10:14)...   Mar 12 2014, 06:13
- - Alexsandr000   Цитата(olegras @ Mar 12 2014, 10:13) Позд...   Mar 12 2014, 07:03
RSS Текстовая версия Сейчас: 26th August 2025 - 13:21
Страница сгенерированна за 0.01365 секунд с 7
