помогите найти общий язык, Quartus 16.1.2 |
Sep 8 2017, 14:10
я только учусь...
Из: Украина
Пользователь №: 24 839
Пожалуйста помогите разобраться. Квартус выдает ошибку Цитата Error (10327): VHDL error at SMC.vhd(68): can't determine definition of operator ""sra"" -- found 0 possible definitions Error (10411): VHDL Type Conversion error at SMC.vhd(68): can't determine type of object or expression near text or symbol "std_logic_vector" в проекте стоит галочка использовать VHDL 2008 ошибка возникает в следующем описании: Код library IEEE; use IEEE.STD_LOGIC_1164.ALL; --use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; use ieee.numeric_std.all;
entity SMC is generic ( M : natural := 32 ); Port ( clk : in STD_LOGIC; rst : in STD_LOGIC; en : in STD_LOGIC; Tmax : in STD_LOGIC_VECTOR (31 downto 0); -- maximum timing Nsegment : in STD_LOGIC_VECTOR (7 downto 0); -- total segment acceleration/deceleration T0 : in STD_LOGIC_VECTOR (31 downto 0); --Duty_cycle : in STD_LOGIC_VECTOR (15 downto 0); --ready_period : out STD_LOGIC; out_shim : out STD_LOGIC ); end SMC;
architecture Behavioral of SMC is
COMPONENT shim generic ( N : natural := 3 ); Port ( clk : in STD_LOGIC; rst : in STD_LOGIC; en : in STD_LOGIC; --load : in STD_LOGIC; Period : in STD_LOGIC_VECTOR (N-1 downto 0); Duty_cycle : in STD_LOGIC_VECTOR (N-1 downto 0); ready_period : out STD_LOGIC; out_shim : out STD_LOGIC );
END COMPONENT;
signal reg_period : STD_LOGIC_VECTOR (M-1 downto 0); signal reg_duty_cycle : STD_LOGIC_VECTOR (M-1 downto 0); signal count_period : STD_LOGIC_VECTOR (M-1 downto 0); signal reg_number_of_steps : STD_LOGIC_VECTOR (M-1 downto 0); signal reg_ready_period, reg_segment_ready : STD_LOGIC; signal reg_en_shim, reg_load_shim : STD_LOGIC; signal cnt_segments : STD_LOGIC_VECTOR (15 downto 0); signal reg_number_of_segments : STD_LOGIC_VECTOR (M-1 downto 0); signal cnt : STD_LOGIC_VECTOR (M-1 downto 0); signal reg_duty_segment : STD_LOGIC_VECTOR (M-1 downto 0); signal reg_ena_work : STD_LOGIC;
begin
shim_inst : shim generic map ( N => M) port map ( clk => clk, rst => rst, en => reg_en_shim, --load => reg_load_shim, Period => reg_period, Duty_cycle => reg_duty_cycle, ready_period => reg_ready_period, out_shim => out_shim ); reg_en_shim <= '1'; reg_duty_cycle <= std_logic_vector (unsigned(reg_period) sra 1); process (all) begin if rst = '1' then count_period <= (others=>'0'); reg_period <= T0; reg_number_of_segments <= std_logic_vector (unsigned(Tmax) sra conv_integer(Nsegment)); reg_duty_segment <= std_logic_vector (unsigned(Tmax) sra 0); reg_segment_ready <= '0'; elsif(rising_edge(clk)) then if reg_ena_work = '1' then if cnt = reg_duty_segment then -- k reg_period <= std_logic_vector (unsigned(reg_period) sra 1); reg_segment_ready <= '1'; reg_duty_segment <= std_logic_vector (unsigned(Tmax) sra conv_integer(cnt_segments+1)); else reg_segment_ready <= '0'; if reg_ready_period = '1' then count_period <= count_period + "0000000000000001"; end if; end if; end if; end if; end process;
process (all) begin if rst = '1' then cnt_segments <= (others=>'0'); cnt <= (others=>'0'); elsif(rising_edge(clk)) then if reg_segment_ready = '1' then cnt_segments <= cnt_segments + "0000000000000001"; cnt <= (others=>'0'); else cnt <= cnt + 1; end if;
process (all) begin if rst = '1' then reg_ena_work <= '0'; elsif(rising_edge(clk)) then if (cnt_segments = Nsegment) then reg_ena_work <= '0'; elsif en = '1' then reg_ena_work <= '1'; end if;
end Behavioral;
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use IEEE.NUMERIC_STD.ALL;
entity shim is generic ( N : natural := 3 ); Port ( clk : in STD_LOGIC; rst : in STD_LOGIC; en : in STD_LOGIC; --load : in STD_LOGIC; Period : in STD_LOGIC_VECTOR (N-1 downto 0); Duty_cycle : in STD_LOGIC_VECTOR (N-1 downto 0); ready_period : out STD_LOGIC; out_shim : out STD_LOGIC ); end shim;
architecture Behavioral of shim is
signal count_shim : STD_LOGIC_VECTOR (N-1 downto 0); signal reg_Period : STD_LOGIC_VECTOR (N-1 downto 0); signal reg_Duty_cycle : STD_LOGIC_VECTOR (N-1 downto 0);
begin
process (all) begin if rst = '1' then count_shim <= (others=>'0'); elsif(rising_edge(clk)) then if en = '1' then if count_shim = reg_Period then ready_period <= '1'; count_shim <= (others=>'0'); else count_shim <= count_shim + std_logic_vector( to_unsigned(1, count_shim'length )); ready_period <= '0'; end if; end if; end if; end process;
process (all) begin if rst = '1' then out_shim <= '0'; elsif(rising_edge(clk)) then if count_shim < reg_Duty_cycle then out_shim <= '1'; else out_shim <= '0'; end if; end if; end process;
process (all) begin if rst = '1' then reg_Period <= (others=>'0'); reg_Duty_cycle <= (others=>'0'); elsif(rising_edge(clk)) then if ready_period = '1' then reg_Period <= Period; reg_Duty_cycle <= Duty_cycle; end if; end if; end process;
end Behavioral; ошибка ссылается на строку reg_duty_cycle <= std_logic_vector (unsigned(reg_period) sra 1); Моделсим 10.5 ошибок не выдает - моделирует...
If it doesn't work in simulation, it won't work on the board.
"Ты живешь в своих поступках, а не в теле. Ты — это твои действия, и нет другого тебя" Антуан де Сент-Экзюпери повесть "Маленький принц"
Sep 8 2017, 15:31
Из: Balakhna
Пользователь №: 937
--use IEEE.STD_LOGIC_UNSIGNED.ALL; - это никогда не использовать. use ieee.numeric_std.all; - только это и соответственно srl. ------------------------------------------------------------------------------ -- Note: Function S.11 is not compatible with IEEE Std 1076-1987. Comment -- out the function (declaration and body) for IEEE StdL 1076-1987 compatibility. ------------------------------------------------------------------------------ -- Id: S.11 function "srl" (ARG: UNSIGNED; COUNT: INTEGER) return UNSIGNED; -- Result subtype: UNSIGNED(ARG'LENGTH-1 downto 0) -- Result: SHIFT_RIGHT(ARG, COUNT) -- Id: S.2 function SHIFT_RIGHT (ARG: UNSIGNED; COUNT: NATURAL) return UNSIGNED; -- Result subtype: UNSIGNED(ARG'LENGTH-1 downto 0) -- Result: Performs a shift-right on an UNSIGNED vector COUNT times. -- The vacated positions are filled with '0'. -- The COUNT rightmost elements are lost. https://standards.ieee.org/downloads/1076/1...umeric_std.vhdl
Sep 11 2017, 09:21
Из: Balakhna
Пользователь №: 937
Цитата(_Anatoliy @ Sep 11 2017, 11:58) Да это не вывод, это вопрос, для себя вывод я сделал давно. Просто хочется знать что думают коллеги. ссылкаВедь мои самописные библиотеки никто не стандартизировал. Дело не в стандартизированности, обе библиотеки стандартизированы, обе библиотеки определяют знаковые типы и операции с ними, какую из них компилятор должен использовать? Это просто ошибка и бестолковщина, как минимум использовать нужно какую-то одну, лучше последнюю стандартизированную numeric_std, но ни в коем случае не обе одновременно в одном entity.
Sep 12 2017, 08:17
я только учусь...
Из: Украина
исправил так Код library IEEE; use IEEE.STD_LOGIC_1164.ALL; --use IEEE.STD_LOGIC_ARITH.ALL; --use IEEE.STD_LOGIC_UNSIGNED.ALL; use ieee.numeric_std.all;
END COMPONENT;
signal reg_period : STD_LOGIC_VECTOR (M-1 downto 0); signal reg_duty_cycle : STD_LOGIC_VECTOR (M-1 downto 0); signal count_period : STD_LOGIC_VECTOR (M-1 downto 0); signal reg_number_of_steps : STD_LOGIC_VECTOR (M-1 downto 0); signal reg_ready_period, reg_segment_ready : STD_LOGIC; signal reg_en_shim, reg_load_shim : STD_LOGIC; signal cnt_segments, cnt_segments1 : STD_LOGIC_VECTOR (15 downto 0); signal reg_number_of_segments : STD_LOGIC_VECTOR (M-1 downto 0); signal cnt : STD_LOGIC_VECTOR (M-1 downto 0); signal reg_duty_segment : STD_LOGIC_VECTOR (M-1 downto 0); signal reg_ena_work : STD_LOGIC;
begin
shim_inst : shim generic map ( N => M) port map ( clk => clk, rst => rst, en => reg_en_shim, --load => reg_load_shim, Period => reg_period, Duty_cycle => reg_duty_cycle, ready_period => reg_ready_period, out_shim => out_shim ); reg_en_shim <= '1'; reg_duty_cycle <= std_logic_vector (SHIFT_RIGHT(unsigned(reg_period), 1)); cnt_segments1 <= std_logic_vector (unsigned(cnt_segments) + 1); process (all) begin if rst = '1' then count_period <= (others=>'0'); reg_period <= T0; reg_number_of_segments <= std_logic_vector (SHIFT_RIGHT(unsigned(Tmax), to_integer(unsigned(Nsegment)))); reg_duty_segment <= std_logic_vector (SHIFT_RIGHT(unsigned(Tmax), 0)); reg_segment_ready <= '0'; elsif(rising_edge(clk)) then if reg_ena_work = '1' then if cnt = reg_duty_segment then -- k reg_period <= std_logic_vector (SHIFT_RIGHT(unsigned(reg_period), 1)); reg_segment_ready <= '1'; reg_duty_segment <= std_logic_vector (SHIFT_RIGHT(unsigned(Tmax), to_integer(unsigned(cnt_segments1)))); else reg_segment_ready <= '0'; if reg_ready_period = '1' then count_period <= count_period + "0000000000000001"; end if; end if; end if; end if; end process;
end Behavioral;
begin
end Behavioral; ошибка Цитата Error (10327): VHDL error at SMC.vhd(90): can't determine definition of operator ""+"" -- found 0 possible definitions во втором описании тоже тогда надо убирать библиотеку - use ieee.std_logic_unsigned.all;
Sep 12 2017, 08:34
В поисках себя...
Из: Санкт-Петербург
Пользователь №: 77 140
Цитата(Maverick @ Sep 12 2017, 11:17) Ну так и правильно, операция + не определена для SLV. Хотите счетчик на SLV, тогда явно преобразуйте типы, например: Код count_period <= std_logic_vector(unsigned(count_period) + 1); cnt_segments <= std_logic_vector(unsigned(cnt_segments) + 1); cnt <= std_logic_vector(unsigned(cnt) + 1); Или сразу объявляйте счетчики как UNSIGNED, тогда можно обойтись такой записью: Код count_period <= count_period + "1"; cnt_segments <= cnt_segments + "1"; cnt <= cnt + "1"; ;
Сообщение отредактировал Flip-fl0p - Sep 12 2017, 08:39
Sep 12 2017, 08:42
я только учусь...
Из: Украина
в чем разница Цитата cnt_segments1 <= std_logic_vector (unsigned(cnt_segments) + 1); у меня сделано так ??? PS это ошибка для первого описания....
Sep 12 2017, 08:49
В поисках себя...
Из: Санкт-Петербург
PS это ошибка для первого описания.... Так во втором описании так-же присутствует эта ошибка: Код count_period <= count_period + "0000000000000001";
Сообщение отредактировал Flip-fl0p - Sep 12 2017, 08:50
Sep 12 2017, 09:22
я только учусь...
Из: Украина
Цитата(Flip-fl0p @ Sep 12 2017, 11:49) спасибо... тему можно закрывать... да, получилось следующим образом: Код library IEEE; use IEEE.STD_LOGIC_1164.ALL; --use IEEE.STD_LOGIC_ARITH.ALL; --use IEEE.STD_LOGIC_UNSIGNED.ALL; use ieee.numeric_std.all;
entity SMC is generic ( M : natural := 32 ); Port ( clk : in STD_LOGIC; rst : in STD_LOGIC; en : in STD_LOGIC; load : in STD_LOGIC; Tmax : in STD_LOGIC_VECTOR (31 downto 0); -- maximum timing Nsegment : in STD_LOGIC_VECTOR (7 downto 0); -- total segment acceleration/deceleration T0 : in STD_LOGIC_VECTOR (31 downto 0); --Duty_cycle : in STD_LOGIC_VECTOR (15 downto 0); --ready_period : out STD_LOGIC; out_shim : out STD_LOGIC ); end SMC;
END COMPONENT;
begin
shim_inst : shim generic map ( N => M) port map ( clk => clk, rst => rst, en => reg_en_shim, --load => reg_load_shim, Period => reg_period, Duty_cycle => reg_duty_cycle, ready_period => reg_ready_period, out_shim => out_shim ); reg_en_shim <= '1'; reg_duty_cycle <= std_logic_vector (SHIFT_RIGHT(unsigned(reg_period), 1)); process (all) begin if rst = '1' then count_period <= (others=>'0'); reg_period <= (others=>'0'); reg_number_of_segments <= (others=>'0'); reg_duty_segment <= (others=>'0'); reg_segment_ready <= '0'; elsif(rising_edge(clk)) then
if load = '1' and reg_ena_work = '0' then reg_period <= T0; reg_number_of_segments <= std_logic_vector (SHIFT_RIGHT(unsigned(Tmax), to_integer(unsigned(Nsegment)))); reg_duty_segment <= std_logic_vector (SHIFT_RIGHT(unsigned(Tmax), 0)); end if;
if reg_ena_work = '1' and load = '0' then if cnt = reg_duty_segment then -- k reg_period <= std_logic_vector (SHIFT_RIGHT(unsigned(reg_period), 1)); reg_segment_ready <= '1'; reg_duty_segment <= std_logic_vector (SHIFT_RIGHT(unsigned(Tmax), to_integer(unsigned(cnt_segments) +1 ))); else reg_segment_ready <= '0'; if reg_ready_period = '1' then count_period <= std_logic_vector (unsigned(count_period) + 1); end if; end if; end if; end if; end process;
process (all) begin if rst = '1' then cnt_segments <= (others=>'0'); cnt <= (others=>'0'); elsif(rising_edge(clk)) then if reg_segment_ready = '1' then cnt_segments <= std_logic_vector (unsigned(cnt_segments) + 1); cnt <= (others=>'0'); else cnt <= std_logic_vector (unsigned(cnt) + 1); end if;
process (all) begin if rst = '1' then reg_ena_work <= '0'; elsif(rising_edge(clk)) then if (unsigned(cnt_segments) = unsigned(Nsegment)) then reg_ena_work <= '0'; elsif en = '1' then reg_ena_work <= '1'; end if;
end Behavioral;
library ieee; use ieee.std_logic_1164.all; --use ieee.std_logic_unsigned.all; use IEEE.NUMERIC_STD.ALL;
begin
process (all) begin if rst = '1' then count_shim <= (others=>'0'); elsif(rising_edge(clk)) then if en = '1' then if count_shim = reg_Period then ready_period <= '1'; count_shim <= (others=>'0'); else count_shim <= std_logic_vector (unsigned(count_shim) + 1); ready_period <= '0'; end if; end if; end if; end process;
end Behavioral;
