Как избавиться от диодов в схеме, переключение диапазонов питания |
Atlantis- Как избавиться от диодов в схеме Oct 12 2017, 08:08 Gorby Цитата(Atlantis- @ Oct 12 2017, 10:0... Oct 12 2017, 08:15 Mikhail241 Цитата(Gorby @ Oct 12 2017, 15:15) Постав... Oct 12 2017, 08:22 Atlantis- Цитата(Gorby @ Oct 12 2017, 11:15) Постав... Oct 12 2017, 08:38  novikovfb Цитата(Atlantis- @ Oct 12 2017, 12:3... Oct 12 2017, 08:42   iosifk Цитата(novikovfb @ Oct 12 2017, 11:42) да... Oct 12 2017, 08:50    Atlantis- Цитата(iosifk @ Oct 12 2017, 11:50) Или п... Oct 12 2017, 11:04   Atlantis- Цитата(novikovfb @ Oct 12 2017, 11:42) да... Oct 12 2017, 09:03    novikovfb Цитата(Atlantis- @ Oct 12 2017, 13:0... Oct 12 2017, 09:07     Atlantis- Цитата(novikovfb @ Oct 12 2017, 12:07) то... Oct 12 2017, 09:11      Atlantis- Цитата(Atlantis- @ Oct 12 2017, 12:1... Oct 12 2017, 15:22       Abell Atlantis-, при питании +/-5 Вольт какой ток нагруз... Oct 12 2017, 15:54        Atlantis- Цитата(Abell @ Oct 12 2017, 18:54) Atlant... Oct 12 2017, 17:06         Abell Цитата(Atlantis- @ Oct 12 2017, 20:0... Oct 13 2017, 11:28          Atlantis- Цитата(Abell @ Oct 13 2017, 15:28) Одну-к... Oct 13 2017, 12:27           Alexashka Цитата(Atlantis- @ Oct 13 2017, 16:2... Oct 13 2017, 13:26            Atlantis- Цитата(Alexashka @ Oct 13 2017, 17:26) Ло... Oct 13 2017, 14:22             Alexashka Цитата(Atlantis- @ Oct 13 2017, 18:2... Oct 16 2017, 08:37              Atlantis- Цитата(Alexashka @ Oct 16 2017, 12:37) Ну... Oct 16 2017, 12:17               Alexashka Цитата(Atlantis- @ Oct 16 2017, 16:1... Oct 16 2017, 13:32                Atlantis- Цитата(Alexashka @ Oct 16 2017, 17:32) У ... Oct 16 2017, 14:21       Alexashka Цитата(Atlantis- @ Oct 12 2017, 19:2... Oct 13 2017, 07:12        Atlantis- Цитата(Alexashka @ Oct 13 2017, 11:12) Ес... Oct 13 2017, 07:35         Alexashka Цитата(Atlantis- @ Oct 13 2017, 11:3... Oct 13 2017, 08:11          Atlantis- Цитата(Alexashka @ Oct 13 2017, 12:11) Ко... Oct 13 2017, 08:22           novikovfb Цитата(Atlantis- @ Oct 13 2017, 12:2... Oct 13 2017, 08:57            Atlantis- Цитата(novikovfb @ Oct 13 2017, 12:57) Ка... Oct 13 2017, 09:18           Alexashka Цитата(Atlantis- @ Oct 13 2017, 12:2... Oct 13 2017, 09:08            Atlantis- Цитата(Alexashka @ Oct 13 2017, 13:08) Пр... Oct 13 2017, 09:32             Alexashka Цитата(Atlantis- @ Oct 13 2017, 13:3... Oct 13 2017, 09:45              Atlantis- Цитата(Alexashka @ Oct 13 2017, 13:45) Я ... Oct 13 2017, 09:56 novikovfb Можно поставить вместо диодов транзисторные ключи ... Oct 12 2017, 08:23 Mikhail241 Цитата(Atlantis- @ Oct 12 2017, 15:0... Oct 12 2017, 08:28 @Ark Цитата(Atlantis- @ Oct 12 2017, 11:0... Oct 12 2017, 11:59 Atlantis- Цитата(@Ark @ Oct 12 2017, 14:59) Если не... Oct 12 2017, 12:58 Abell Предложил бы применить не переключатели (это, кста... Oct 12 2017, 17:29 Atlantis- Цитата(Abell @ Oct 12 2017, 21:29) Предло... Oct 12 2017, 18:13  Abell Цитата(Atlantis- @ Oct 12 2017, 21:1... Oct 13 2017, 08:46   Atlantis- Цитата(Abell @ Oct 13 2017, 12:46) При от... Oct 13 2017, 08:50 Burner Это все довольно просто, и ШИМ там не нать.. Разве... Oct 12 2017, 19:54 Abell Стало быть, сетевое питание... Трансформатор обычн... Oct 13 2017, 08:53 Atlantis- Цитата(Abell @ Oct 13 2017, 12:53) Стало ... Oct 13 2017, 09:00  Abell Цитата(Atlantis- @ Oct 13 2017, 12:0... Oct 13 2017, 09:22 blackfin Цитата(Atlantis- @ Oct 12 2017, 11:0... Oct 13 2017, 09:02 Alexashka ЦитатаТогда получается что он всегда закрыт...пото... Oct 13 2017, 10:42 Atlantis- Цитата(Alexashka @ Oct 13 2017, 14:42) Кс... Oct 13 2017, 11:45  novikovfb Цитата(Atlantis- @ Oct 13 2017, 15:4... Oct 13 2017, 11:55 GefarD А аналоговые ключи не подойдут? DG469 Oct 14 2017, 20:19 Atlantis- Цитата(GefarD @ Oct 15 2017, 00:19) А ана... Oct 14 2017, 21:52 GefarD возможно другие есть с лучшими параметрами Oct 15 2017, 14:33 GefarD Самое простое что пришло - диод,резистор, конденса... Oct 16 2017, 20:23 Atlantis- Цитата(GefarD @ Oct 17 2017, 00:23) Самое... Oct 17 2017, 08:02 Alexashka Может не туда подключаете? Oct 17 2017, 13:22 Atlantis- Цитата(Alexashka @ Oct 17 2017, 17:22) Мо... Oct 17 2017, 13:28  Alexashka Цитата(Atlantis- @ Oct 17 2017, 17:2... Oct 18 2017, 07:16   Atlantis- Цитата(Alexashka @ Oct 18 2017, 11:16) В ... Oct 18 2017, 07:27 VCO Цитата(Atlantis- @ Oct 12 2017, 11:0... Oct 17 2017, 19:38 Atlantis- Цитата(VCO @ Oct 17 2017, 23:38) Теоретич... Oct 17 2017, 19:51 GefarD Можно диод и конденсатор применить нестандартно. Р... Oct 18 2017, 06:38 Alexashka . Oct 18 2017, 07:30 Atlantis- Ах Вы про это...на полевом транзисторе задержки бо... Oct 18 2017, 07:55 Alexashka А какие нужны задержки? Oct 18 2017, 08:37 Atlantis- Цитата(Alexashka @ Oct 18 2017, 12:37) А ... Oct 18 2017, 09:37 GefarD Может биполярные другие выбрать? Oct 18 2017, 19:36 Alexashka Достаточно задержки гарантирующей что транзисторы ... Oct 19 2017, 06:01 Atlantis- Цитата(Alexashka @ Oct 19 2017, 10:01) До... Oct 19 2017, 12:55  Alexashka Цитата(Atlantis- @ Oct 19 2017, 16:5... Oct 20 2017, 05:55   Atlantis- Цитата(Alexashka @ Oct 20 2017, 09:55) Пр... Oct 20 2017, 07:50    Plain Цитата(Atlantis- @ Oct 20 2017, 10:5... Oct 31 2017, 02:34 ViKo Поставили бы в источниках питания регуляторы с реж... Oct 19 2017, 13:44 Atlantis- Цитата(ViKo @ Oct 19 2017, 17:44) Постави... Oct 19 2017, 14:07 smk Не вполне ясна исходная задача, но почему нельзя о... Oct 19 2017, 17:08 Plain Автор уже много лет разрабатывает некий якобы ауди... Oct 19 2017, 21:46 Smen Цитата(Plain @ Oct 20 2017, 02:46) с одно... Oct 20 2017, 08:47 Atlantis- Порыскал в интернете, оказывается "идеальные ... Oct 25 2017, 10:01 Atlantis- Проблема этой схемы для меня - высокое напряжение ... Oct 26 2017, 14:13 Alexashka Цитата(Atlantis- @ Oct 26 2017, 18:1... Oct 28 2017, 06:26  Atlantis- Цитата(Alexashka @ Oct 28 2017, 09:26) Па... Oct 30 2017, 07:04 vladec Цитатаоказывается "идеальные диоды" на M... Oct 27 2017, 07:33 Alexashka Ну почему же не рабочая. Если подобрать падение на... Oct 30 2017, 08:55 Atlantis- Цитата(Alexashka @ Oct 30 2017, 11:55) Ну... Nov 14 2017, 14:58  Alexashka Цитата(Atlantis- @ Nov 14 2017, 18:5... Nov 15 2017, 06:59 Atlantis- А как это все будет меняться от температуры? Не по... Oct 30 2017, 14:46 Alexashka Вы даже немножко сами не хотите подумать. А что с ... Oct 31 2017, 00:31 Atlantis- Цитата(Alexashka @ Oct 31 2017, 03:31) Вы... Nov 2 2017, 09:36  Plain Цитата(Atlantis- @ Nov 2 2017, 12:36... Nov 3 2017, 02:47  Alexashka Цитата(Atlantis- @ Nov 2 2017, 13:36... Nov 3 2017, 17:10   Atlantis- Цитата(Alexashka @ Nov 3 2017, 20:10) Ну ... Nov 4 2017, 10:11    Alexashka Цитата(Atlantis- @ Nov 4 2017, 14:11... Nov 4 2017, 12:55     Atlantis- Цитата(Alexashka @ Nov 4 2017, 15:55) Но ... Nov 5 2017, 14:20      Alexashka Цитата(Atlantis- @ Nov 5 2017, 18:20... Nov 5 2017, 18:28       Atlantis- Цитата(Alexashka @ Nov 5 2017, 21:28) Да ... Nov 7 2017, 08:19        Alexashka Цитата(Atlantis- @ Nov 7 2017, 12:19... Nov 7 2017, 08:54         Atlantis- Цитата(Alexashka @ Nov 7 2017, 11:54) Раз... Nov 7 2017, 10:12          Alexashka Цитата(Atlantis- @ Nov 7 2017, 14:12... Nov 7 2017, 12:05 GefarD а засем городить огород с полевиком когда есть гот... Nov 4 2017, 15:42 Atlantis- Тут тогда тоже что-ли про защиту обратной полярнос... Nov 11 2017, 12:18 Alexashka Цитата(Atlantis- @ Nov 11 2017, 16:1... Nov 11 2017, 23:06  Atlantis- Цитата(Alexashka @ Nov 12 2017, 02:06) А ... Nov 12 2017, 11:34 Alexashka Да. Я больше доверяю даташиту, а там как я уже при... Nov 12 2017, 15:45
4 чел. читают эту тему (гостей: 4, скрытых пользователей: 0)
