10 страниц V  « < 2 3 4 5 6 > »
> QUARTUS, MODELSIM, Проект по переводу документации
Kuzmi4
сообщение Oct 30 2009, 10:38
Сообщение #46
Из: 55°55′5″ 37°52′16″
Пользователь №: 25 329
Добрался до страницы 9 - всё нормально
лог консоли
CODE
cd D:/Tmp/23
# reading C:\modeltech_6.5b\win32/../modelsim.ini
do D:/Tmp/23/compile.do
# Copying C:\modeltech_6.5b\win32/../modelsim.ini to modelsim.ini
# Modifying modelsim.ini
# ** Warning: Copied C:\modeltech_6.5b\win32/../modelsim.ini to modelsim.ini.
# Updated modelsim.ini.
# -- Compiling module cache
# -- Compiling module memory
# -- Compiling module proc
# Top level modules:
# cache
# memory
# proc
# -- Loading package standard
# -- Loading package std_logic_1164
# -- Compiling package std_logic_util
# -- Compiling package body std_logic_util
# -- Loading package std_logic_util
# -- Compiling entity cache_set
# -- Compiling architecture only of cache_set
# -- Compiling entity top
# -- Compiling architecture only of top
vsim work.top
# vsim work.top
# ** Note: (vsim-3812) Design is being optimized...
# Loading std.standard
# Loading ieee.std_logic_1164(body)
# Loading work.top(only)#1
# Loading work.proc(fast)
# Loading work.cache(fast)
# Loading work.std_logic_util(body)
# Loading work.cache_set(only)#1
# Loading work.memory(fast)
run 100ns
# 20: Starting Read/Write test
# 20: Writing data=0000 to addr=00
# 60: Write miss, picking set 3
run -all
# 220: Writing data=0001 to addr=01
# 260: Write miss, picking set 3
# 420: Writing data=0002 to addr=02
# 460: Write miss, picking set 3
# 620: Writing data=0003 to addr=03
# 660: Write miss, picking set 3
# 820: Writing data=0004 to addr=04
# 860: Write miss, picking set 3
# 1020: Writing data=0005 to addr=05
# 1060: Write miss, picking set 3
# 1220: Writing data=0006 to addr=06
# 1260: Write miss, picking set 3
# 1420: Writing data=0007 to addr=07
# 1460: Write miss, picking set 3
# 1620: Writing data=0008 to addr=08
# 1660: Write miss, picking set 3
# 1820: Writing data=0009 to addr=09
# 1860: Write miss, picking set 3
# 2020: Reading from addr=00
# 2060: Read hit to set 3
# 2100: Reading from addr=01
# 2140: Read hit to set 3
# 2180: Reading from addr=02
# 2220: Read hit to set 3
# 2260: Reading from addr=03
# 2300: Read hit to set 3
# 2340: Reading from addr=04
# 2380: Read hit to set 3
# 2420: Reading from addr=05
# 2460: Read hit to set 3
# 2500: Reading from addr=06
# 2540: Read hit to set 3
# 2580: Reading from addr=07
# 2620: Read hit to set 3
# 2660: Reading from addr=08
# 2700: Read hit to set 3
# 2740: Reading from addr=09
# 2780: Read hit to set 3
# Read/Write test done
# ** Note: $stop : proc.v(75)
# Time: 2820 ns Iteration: 0 Instance: /top/p
# Break at proc.v line 75
torik
сообщение Oct 30 2009, 10:50
Сообщение #47
Пользователь №: 10 359
На своем проекте у меня не ругается, но я хочу именно лабы. Мне непонятно даже, откуда берутся тестовые сигналы (прописаны в тестбенче?), хочу понять вообще основы моделирования, связь с квартусом, как пользоваться тестбенчами...
modelsim6.4a
Кстати, при выполненении do compile.do все проходит нормально, а двойной щелчек на top дает ошибку...
Быть. torizin-liteha@yandex.ru
Kuzmi4
сообщение Oct 30 2009, 11:17
Сообщение #48
2 torik - вышеприведённые действия делал с файлами с директории "modelsim_data_6.2c.zip/modelsim_lab/modsim_lab1"
torik
сообщение Oct 30 2009, 11:39
Сообщение #49
Да про них и речь
Версия моделсима какая? Не мог бы кто-нибудь попробовать эти лабы в версии 6.4а? А то споткнулся в самом начале, ошибка непойми о чем, какие действия можно предпринять неясно...
Kuzmi4
сообщение Oct 30 2009, 11:56
Сообщение #50
ModelSim SE 6.5b May 21 2009
6.4а снёс месяца 3 назад...
torik
сообщение Oct 30 2009, 11:58
Сообщение #51
А чё?
Да и в любом случае, какого хрена, что это за ошибка, в чем ее суть? Ну не загрузить, а дальше что...
Это что, из-за того, что не было таблетки от жадности, поддерживает не более одного файла HDL?
Ну допустим, поставлю ModelSim SE 6.5b May 21 2009 - где взять сей инструмент с таблеткой вместе?
Kuzmi4
сообщение Oct 30 2009, 12:02
Сообщение #52
Цитата(torik @ Oct 30 2009, 13:58) *
А чё?
Дизайны стали очень привязаны к специфике виртексов, а в 11-й версии аси - непринятие А-релизов.
судя по всему у вас МС не можен найти энтити задекларированные в топе.
Двойной щелчёк - это вроде
vsim work.top
torik
сообщение Oct 30 2009, 12:16
Сообщение #53
У меня сейчас вообще моделсим альтера стартер, может мы говорим совершенно о разных вещах и я зря стараюсь запустить на нем эти лабы?
Да это и так ясно, но что я могу тут сделать, файлы-то есть, чего ему еще надо...
Kuzmi4
сообщение Oct 30 2009, 12:28
Сообщение #54
В этом как раз может быть проблема - у меня ж ModelSim SE 6.5b May 21 2009
Лог с консоли приведите, может проясниться что
torik
сообщение Nov 24 2009, 12:46
Сообщение #55
Хочу вернуться к вопросу о моделсиме. Подскажите, где вообще можно что-то попроще почитать о тестбенчах, куда их прикручивать, как писать... А потом уже о моделсиме.
des00
сообщение Nov 24 2009, 12:52
Сообщение #56
Вечный ламер
Из: Томск
Пользователь №: 3 453
в тему про SV, там линки и книги
torik
сообщение Nov 24 2009, 14:05
Сообщение #57
Мне бы что-то совсем простое, типа примера простенького тестбенча, как при этом должен выглядеть проект в квартусе, как его передать в моделсим и посмотреть что получается. Для начала что-то вроде счетчика, триггера....
Iptash
сообщение Nov 24 2009, 15:14
Сообщение #58
Из: г.Набережные Челны
Пользователь №: 39 936
Вот недавно где то выкладывал:
module countbit(
        input clk,             //такт...
        input [7:0] data,      //данные
        input load,            //загрузка данных
        output reg fin,        //флаг, счет закончен
        output reg [4:0] count //результат
    bit [7:0] tempbuff;
    always @ (posedge clk or posedge load) begin
      if(load) begin
        tempbuff <= data;
        fin <= 0;
        count <= 0;
      end
     else begin
        if(tempbuff[0]) begin
          tempbuff <= tempbuff >> 1;
          count++;
        end
      else fin <= 1;
     end
   end
endmodule
module test;
  bit clk;
  bit [7:0] data;
  bit load;
  bit fin;
  bit [4:0] count;
    initial begin
     clk = 0;
     data = 0;
     load = 0;
    #5 data = 8'b11001111;
    #5 load = 1;
    #2 load = 0;
    wait(fin == 1); //Ждать пока счет не закончен
    #5 data = 8'b10101011;
    #5 load =1;
    #2 load = 0;
    #5 $stop;
    end
    always #2 clk = ~clk;
countbit P1 (
   .clk(clk),
   .data(data),
   .load(load),
   .fin(fin),
   .count(count)
endmodule
Собственно программа подсчитыват количество бит прва на лево (с мл. бита) до первого значащего нуля. Не обязательно с самого начала создавать проект в квартусе. Можно сначало
в модель симе создать, писать, симулировать, а потом синтезировать в квартусе. Я сам все это поверхностно изучил, так, что не обессудь. Что не понятно в программе спрашивай, а так
создай проект в модель симе, просимулируй, должно быть все понятно.
des00
сообщение Nov 25 2009, 03:57
Сообщение #59
Вечный ламер
Из: Томск
следите за форумом, например здесь я выкладывал проект с простым тестбенчем
torik
сообщение Nov 25 2009, 06:11
Сообщение #60
Iptash, спасибо. Как раз то что надо для понимания связи тестбенча и собственно описания девайса. Вот только моделсим 6.4а у меня тупит, похоже что он просто не работает, качаю 9.1...
А дальше буду вопросы как это в моделсиме запустить.
RSS Текстовая версия Сейчас: 26th August 2025 - 08:27
Страница сгенерированна за 0.0151 секунд с 7
