> МК на температуру < -40º С
war4one
сообщение May 15 2007, 09:12
Из: г. Уфа
Пользователь №: 6 851
Есть ли в природе доставабельные МК на мороз -50º, -60º С? Или это фантастика?
Электронные устройства Open Hardware
doomer#gp
сообщение May 15 2007, 10:56
Из: USA
Пользователь №: 3 234
Есть варианты MPC5553/MPC5554 ( MPC5554AZP132 ) на -55С, на freescale цена $130.17 за штуку при партияк >1000.
Это PowerPC BookE e200, есть FPU, тактовая 132 MHz.
У католожников не меньнше $250
Вот краткое описание:
Freescale’s e200z6 Core
High-performance 132 MHz 32-bit PowerPC Book E-compliant core
Memory management unit (MMU) with 32-entry fully associative translation lookaside buffer (TLB)
SPE (signal processing extension): DSP, SIMD and floating point capabilities
Memory
2 MB of embedded Flash memory with Error Correction Coding (ECC) and Read While Write capability (RWW)
64 KB on-chip static RAM with Error Correction Coding (ECC)
32 KB of cache (with line-locking) that can be configured as additional RAM
System
Two enhanced time processor units (eTPUs) with 64 I/O channels and 19k of designated SRAM
64-channel eDMA (Enhanced Direct Memory Access) controller
Interrupt controller (INTC) capable of handling 286 selectable-priority interrupt sources
Frequency modulated phase-locked loop (FMPLL) to assist in electromagnetic interference (EMI) management
MPC500 compatible External Bus Interface
Nexus IEEE-ISTO 5001™ Class 3+ multicore debug capabilities
5/3.3V IO, 5V ADC, 3.3V/1.8V bus, 1.5V core
416 pin PBGA package
Temperature Range: -40 to 125?C
Optional Temperature Range: -55 to 125?C
I/O
40 channel dual Enhanced queued analog-to-digital converter (eQADC) - up to 12 bit resolution and up to 1.25ms conversions, 6 queues with triggering and DMA support
Four deserial serial peripheral
Interface (DSPI) modules - 16 bits wide up to 6 chip selects each
Three controller area
Network (CAN) modules with 64 buffers each
Two enhanced serial communication
Interface (eSCI) modules
24 channel enhanced multiple I/O system (EMIOS) with unified channels
Еrrata приличная, косяки с programm flash.
war4one
сообщение May 15 2007, 23:37
Из: г. Уфа
Спасибо, некислый проц smile.gif Буду знать, что хоть что-то есть.
Так и не удалось найти МК на замену примерно ATmega32-128, с соответствующей ценой. > +100 - пожалуйста, многие держат, а морозоустойчивого - ничего, даже атмелевские четырехбитки MARC4 - и те только до -40.
Придется делать девайс по старинке - аналоговая схемка решает, надо ли включать подогрев и подавать питание на остальную схему.
-=Sergei=-
сообщение May 16 2007, 03:03
Пользователь №: 985
http://www.milandr.ru/product/mc/1886BE2Y
vetal
сообщение May 16 2007, 04:13
Из: Россия, СПб
Пользователь №: 553
http://www.niiet.ru/acrobat/TO1882BE52Y_4.pdf
http://www.niiet.ru/acrobat/a1882BE53Y.pdf
ELVEES R&D C...
сообщение Jul 5 2007, 10:24
Пользователь №: 23 950
есть отечественные DSP процессоры Мультикор (серия 1892) с MIPS32 RISC-контроллером на кристалле
рабочий температурный диапазон от минус 60 до +85, частота 80 МГц (для 1892ВМ5Я - 100 МГц)
описание и цены на сайте http://multicore.ru/
rezident
сообщение Jul 5 2007, 11:11
Пользователь №: 3 882
Вам нужно чтобы именно работал при -55С или чтобы допускал -55С? Ведь не обязательно при работе морозить МК, можно его теплоизолировать и подогревать хотя бы до минимально допустимой рабочей температуры.
sensor_ua
сообщение Jul 7 2007, 08:14
Из: Киев
Пользователь №: 4 387
Допускающих -55 есть 51-е у Atmel- AT89S52, AT89S8253, AT89C51RC
aka Vit
AndreyKeil
сообщение Sep 1 2007, 19:44
Из: г.Екатеринбург
Пользователь №: 10 930
От -55 град.Цельсия работает вся линейка AVR-ок серии "Automotive".
mse
сообщение Sep 3 2007, 05:38
Пользователь №: 4 693
От -40... Есть, правда букевки, которые до +150, но низ -40.
Rst7
сообщение Sep 3 2007, 08:04
Йа моск ;)
Из: Kharkiv-city
Пользователь №: 6 610
Не согласен. ATMega 48/88/168
Operating Temperature.................................. -55°C to +125°C
Storage Temperature ..................................... -65°C to +150°C
Rev. 2545K–AVR–04/07
Это даже не автомобильные, а обычные
AlexG_changed
сообщение Sep 4 2007, 16:34
Группа: Validating
Пользователь №: 6 073
Цитата(Rst7 @ Sep 3 2007, 15:04) *
ATMega 48/88/168 Это даже не автомобильные, а обычные
-55С +125С это предельно допустимые температуры, при них можно гарантировать только что МК не выйдет из строя. Использовать AVR в серийных изделия при температурах ниже -40C нельзя sad.gif
dxp
сообщение Sep 5 2007, 04:49
Adept
Из: Novosibirsk
Пользователь №: 1 343
Специально скачал три DS на указанные МК (автомобильные, обычные и какие-то с суффиксом P), во всех указан нижний предел -40 по рабочей температуте. Это не странно, -55 в обычных МК - это в некотором роде прямо-таки революция.
«Отыщи всему начало, и ты многое поймёшь» К. Прутков
Rst7
сообщение Sep 5 2007, 06:42
Йа моск ;)
Из: Kharkiv-city
Вообще-то действительно... Это же предельно допустимые... И че мне в голову ударило??? Всем пардон, был неправ...
RSS Текстовая версия Сейчас: 21st July 2025 - 13:23
Страница сгенерированна за 0.01561 секунд с 7
