Цитата(drozel @ Oct 12 2015, 14:55)
Зато есть зацепка в папке scripts, скрипт irq2nvic_h, вроде на питоне (судя по строке #!/usr/bin/env python), содержащий, помимо всего прочего,такие строки
"""Generate an nvic.h header from a small JSON file describing the interrupt
numbers.
Code generation is chosen here because the resulting C code needs to be very
repetetive (definition of the IRQ numbers, function prototypes, weak fallback
definition and vector table definition), all being very repetitive. No portable
method to achive the same thing with C preprocessor is known to the author.
(Neither is any non-portable method, for that matter.)"""
Я на питоне не силен, скачал интерпретатор под винду, пытаюсь его как-то запустить. Пока неудачно, но это вопрос скорее в тему по питону.
держите для F4
CODE
/* This file is part of the libopencm3 project.
* It was generated by the irq2nvic_h script.
* This part needs to get included in the compilation unit where
* blocking_handler gets defined due to the way #pragma works.
/** @defgroup CM3_nvic_isrpragmas_STM32F4 User interrupt service routines (ISR) defaults for STM32 F4 series
@ingroup CM3_nvic_isrpragmas
#pragma weak nvic_wwdg_isr = blocking_handler
#pragma weak pvd_isr = blocking_handler
#pragma weak tamp_stamp_isr = blocking_handler
#pragma weak rtc_wkup_isr = blocking_handler
#pragma weak flash_isr = blocking_handler
#pragma weak rcc_isr = blocking_handler
#pragma weak exti0_isr = blocking_handler
#pragma weak exti1_isr = blocking_handler
#pragma weak exti2_isr = blocking_handler
#pragma weak exti3_isr = blocking_handler
#pragma weak exti4_isr = blocking_handler
#pragma weak dma1_stream0_isr = blocking_handler
#pragma weak dma1_stream1_isr = blocking_handler
#pragma weak dma1_stream2_isr = blocking_handler
#pragma weak dma1_stream3_isr = blocking_handler
#pragma weak dma1_stream4_isr = blocking_handler
#pragma weak dma1_stream5_isr = blocking_handler
#pragma weak dma1_stream6_isr = blocking_handler
#pragma weak adc_isr = blocking_handler
#pragma weak can1_tx_isr = blocking_handler
#pragma weak can1_rx0_isr = blocking_handler
#pragma weak can1_rx1_isr = blocking_handler
#pragma weak can1_sce_isr = blocking_handler
#pragma weak exti9_5_isr = blocking_handler
#pragma weak tim1_brk_tim9_isr = blocking_handler
#pragma weak tim1_up_tim10_isr = blocking_handler
#pragma weak tim1_trg_com_tim11_isr = blocking_handler
#pragma weak tim1_cc_isr = blocking_handler
#pragma weak tim2_isr = blocking_handler
#pragma weak tim3_isr = blocking_handler
#pragma weak tim4_isr = blocking_handler
#pragma weak i2c1_ev_isr = blocking_handler
#pragma weak i2c1_er_isr = blocking_handler
#pragma weak i2c2_ev_isr = blocking_handler
#pragma weak i2c2_er_isr = blocking_handler
#pragma weak spi1_isr = blocking_handler
#pragma weak spi2_isr = blocking_handler
#pragma weak usart1_isr = blocking_handler
#pragma weak usart2_isr = blocking_handler
#pragma weak usart3_isr = blocking_handler
#pragma weak exti15_10_isr = blocking_handler
#pragma weak rtc_alarm_isr = blocking_handler
#pragma weak usb_fs_wkup_isr = blocking_handler
#pragma weak tim8_brk_tim12_isr = blocking_handler
#pragma weak tim8_up_tim13_isr = blocking_handler
#pragma weak tim8_trg_com_tim14_isr = blocking_handler
#pragma weak tim8_cc_isr = blocking_handler
#pragma weak dma1_stream7_isr = blocking_handler
#pragma weak fsmc_isr = blocking_handler
#pragma weak sdio_isr = blocking_handler
#pragma weak tim5_isr = blocking_handler
#pragma weak spi3_isr = blocking_handler
#pragma weak uart4_isr = blocking_handler
#pragma weak uart5_isr = blocking_handler
#pragma weak tim6_dac_isr = blocking_handler
#pragma weak tim7_isr = blocking_handler
#pragma weak dma2_stream0_isr = blocking_handler
#pragma weak dma2_stream1_isr = blocking_handler
#pragma weak dma2_stream2_isr = blocking_handler
#pragma weak dma2_stream3_isr = blocking_handler
#pragma weak dma2_stream4_isr = blocking_handler
#pragma weak eth_isr = blocking_handler
#pragma weak eth_wkup_isr = blocking_handler
#pragma weak can2_tx_isr = blocking_handler
#pragma weak can2_rx0_isr = blocking_handler
#pragma weak can2_rx1_isr = blocking_handler
#pragma weak can2_sce_isr = blocking_handler
#pragma weak otg_fs_isr = blocking_handler
#pragma weak dma2_stream5_isr = blocking_handler
#pragma weak dma2_stream6_isr = blocking_handler
#pragma weak dma2_stream7_isr = blocking_handler
#pragma weak usart6_isr = blocking_handler
#pragma weak i2c3_ev_isr = blocking_handler
#pragma weak i2c3_er_isr = blocking_handler
#pragma weak otg_hs_ep1_out_isr = blocking_handler
#pragma weak otg_hs_ep1_in_isr = blocking_handler
#pragma weak otg_hs_wkup_isr = blocking_handler
#pragma weak otg_hs_isr = blocking_handler
#pragma weak dcmi_isr = blocking_handler
#pragma weak cryp_isr = blocking_handler
#pragma weak hash_rng_isr = blocking_handler
#pragma weak fpu_isr = blocking_handler
#pragma weak uart7_isr = blocking_handler
#pragma weak uart8_isr = blocking_handler
#pragma weak spi4_isr = blocking_handler
#pragma weak spi5_isr = blocking_handler
#pragma weak spi6_isr = blocking_handler
#pragma weak sai1_isr = blocking_handler
#pragma weak lcd_tft_isr = blocking_handler
#pragma weak lcd_tft_err_isr = blocking_handler
#pragma weak dma2d_isr = blocking_handler
/* Initialization template for the interrupt vector table. This definition is
* used by the startup code generator (vector.c) to set the initial values for
* the interrupt handling routines to the chip family specific _isr weak
* symbols. */
#define IRQ_HANDLERS \
[NVIC_NVIC_WWDG_IRQ] = nvic_wwdg_isr, \
[NVIC_PVD_IRQ] = pvd_isr, \
[NVIC_TAMP_STAMP_IRQ] = tamp_stamp_isr, \
[NVIC_RTC_WKUP_IRQ] = rtc_wkup_isr, \
[NVIC_FLASH_IRQ] = flash_isr, \
[NVIC_RCC_IRQ] = rcc_isr, \
[NVIC_EXTI0_IRQ] = exti0_isr, \
[NVIC_EXTI1_IRQ] = exti1_isr, \
[NVIC_EXTI2_IRQ] = exti2_isr, \
[NVIC_EXTI3_IRQ] = exti3_isr, \
[NVIC_EXTI4_IRQ] = exti4_isr, \
[NVIC_DMA1_STREAM0_IRQ] = dma1_stream0_isr, \
[NVIC_DMA1_STREAM1_IRQ] = dma1_stream1_isr, \
[NVIC_DMA1_STREAM2_IRQ] = dma1_stream2_isr, \
[NVIC_DMA1_STREAM3_IRQ] = dma1_stream3_isr, \
[NVIC_DMA1_STREAM4_IRQ] = dma1_stream4_isr, \
[NVIC_DMA1_STREAM5_IRQ] = dma1_stream5_isr, \
[NVIC_DMA1_STREAM6_IRQ] = dma1_stream6_isr, \
[NVIC_ADC_IRQ] = adc_isr, \
[NVIC_CAN1_TX_IRQ] = can1_tx_isr, \
[NVIC_CAN1_RX0_IRQ] = can1_rx0_isr, \
[NVIC_CAN1_RX1_IRQ] = can1_rx1_isr, \
[NVIC_CAN1_SCE_IRQ] = can1_sce_isr, \
[NVIC_EXTI9_5_IRQ] = exti9_5_isr, \
[NVIC_TIM1_BRK_TIM9_IRQ] = tim1_brk_tim9_isr, \
[NVIC_TIM1_UP_TIM10_IRQ] = tim1_up_tim10_isr, \
[NVIC_TIM1_TRG_COM_TIM11_IRQ] = tim1_trg_com_tim11_isr, \
[NVIC_TIM1_CC_IRQ] = tim1_cc_isr, \
[NVIC_TIM2_IRQ] = tim2_isr, \
[NVIC_TIM3_IRQ] = tim3_isr, \
[NVIC_TIM4_IRQ] = tim4_isr, \
[NVIC_I2C1_EV_IRQ] = i2c1_ev_isr, \
[NVIC_I2C1_ER_IRQ] = i2c1_er_isr, \
[NVIC_I2C2_EV_IRQ] = i2c2_ev_isr, \
[NVIC_I2C2_ER_IRQ] = i2c2_er_isr, \
[NVIC_SPI1_IRQ] = spi1_isr, \
[NVIC_SPI2_IRQ] = spi2_isr, \
[NVIC_USART1_IRQ] = usart1_isr, \
[NVIC_USART2_IRQ] = usart2_isr, \
[NVIC_USART3_IRQ] = usart3_isr, \
[NVIC_EXTI15_10_IRQ] = exti15_10_isr, \
[NVIC_RTC_ALARM_IRQ] = rtc_alarm_isr, \
[NVIC_USB_FS_WKUP_IRQ] = usb_fs_wkup_isr, \
[NVIC_TIM8_BRK_TIM12_IRQ] = tim8_brk_tim12_isr, \
[NVIC_TIM8_UP_TIM13_IRQ] = tim8_up_tim13_isr, \
[NVIC_TIM8_TRG_COM_TIM14_IRQ] = tim8_trg_com_tim14_isr, \
[NVIC_TIM8_CC_IRQ] = tim8_cc_isr, \
[NVIC_DMA1_STREAM7_IRQ] = dma1_stream7_isr, \
[NVIC_FSMC_IRQ] = fsmc_isr, \
[NVIC_SDIO_IRQ] = sdio_isr, \
[NVIC_TIM5_IRQ] = tim5_isr, \
[NVIC_SPI3_IRQ] = spi3_isr, \
[NVIC_UART4_IRQ] = uart4_isr, \
[NVIC_UART5_IRQ] = uart5_isr, \
[NVIC_TIM6_DAC_IRQ] = tim6_dac_isr, \
[NVIC_TIM7_IRQ] = tim7_isr, \
[NVIC_DMA2_STREAM0_IRQ] = dma2_stream0_isr, \
[NVIC_DMA2_STREAM1_IRQ] = dma2_stream1_isr, \
[NVIC_DMA2_STREAM2_IRQ] = dma2_stream2_isr, \
[NVIC_DMA2_STREAM3_IRQ] = dma2_stream3_isr, \
[NVIC_DMA2_STREAM4_IRQ] = dma2_stream4_isr, \
[NVIC_ETH_IRQ] = eth_isr, \
[NVIC_ETH_WKUP_IRQ] = eth_wkup_isr, \
[NVIC_CAN2_TX_IRQ] = can2_tx_isr, \
[NVIC_CAN2_RX0_IRQ] = can2_rx0_isr, \
[NVIC_CAN2_RX1_IRQ] = can2_rx1_isr, \
[NVIC_CAN2_SCE_IRQ] = can2_sce_isr, \
[NVIC_OTG_FS_IRQ] = otg_fs_isr, \
[NVIC_DMA2_STREAM5_IRQ] = dma2_stream5_isr, \
[NVIC_DMA2_STREAM6_IRQ] = dma2_stream6_isr, \
[NVIC_DMA2_STREAM7_IRQ] = dma2_stream7_isr, \
[NVIC_USART6_IRQ] = usart6_isr, \
[NVIC_I2C3_EV_IRQ] = i2c3_ev_isr, \
[NVIC_I2C3_ER_IRQ] = i2c3_er_isr, \
[NVIC_OTG_HS_EP1_OUT_IRQ] = otg_hs_ep1_out_isr, \
[NVIC_OTG_HS_EP1_IN_IRQ] = otg_hs_ep1_in_isr, \
[NVIC_OTG_HS_WKUP_IRQ] = otg_hs_wkup_isr, \
[NVIC_OTG_HS_IRQ] = otg_hs_isr, \
[NVIC_DCMI_IRQ] = dcmi_isr, \
[NVIC_CRYP_IRQ] = cryp_isr, \
[NVIC_HASH_RNG_IRQ] = hash_rng_isr, \
[NVIC_FPU_IRQ] = fpu_isr, \
[NVIC_UART7_IRQ] = uart7_isr, \
[NVIC_UART8_IRQ] = uart8_isr, \
[NVIC_SPI4_IRQ] = spi4_isr, \
[NVIC_SPI5_IRQ] = spi5_isr, \
[NVIC_SPI6_IRQ] = spi6_isr, \
[NVIC_SAI1_IRQ] = sai1_isr, \
[NVIC_LCD_TFT_IRQ] = lcd_tft_isr, \
[NVIC_LCD_TFT_ERR_IRQ] = lcd_tft_err_isr, \
[NVIC_DMA2D_IRQ] = dma2d_isr
питон можно портабл взять
