Настроил Т2 на измерение время импульсов. Импульс подаю 50Гц -> 20мс
А счетчик дает значение примерно 87136->3.6ms (1 переполнение и рег. захвата). MCK=48MГц или нет?
Настроен на TIMER_CLOCK1->MCK/2
Я не правильно МСК считаю или как??
Стоит кварц 18.432 МГц. стартап: стандарт
// Initialize main oscillator
AT91C_BASE_PMC->PMC_MOR = BOARD_OSCOUNT | AT91C_CKGR_MOSCEN;
while (!(AT91C_BASE_PMC->PMC_SR & AT91C_PMC_MOSCS));
// Initialize PLL at 96MHz (96.109) and USB clock to 48MHz
//18432000Hz / 14 * (72+1) = 96109714MHz
AT91C_BASE_PMC->PMC_PLLR = BOARD_USBDIV | BOARD_CKGR_PLL | BOARD_PLLCOUNT
| BOARD_MUL | BOARD_DIV;
while (!(AT91C_BASE_PMC->PMC_SR & AT91C_PMC_LOCK));
// Wait for the master clock if it was already initialized
while (!(AT91C_BASE_PMC->PMC_SR & AT91C_PMC_MCKRDY));
// Switch to slow clock + prescaler
AT91C_BASE_PMC->PMC_MCKR = BOARD_PRESCALER; //2
таймер:
unsigned int over=0;
unsigned int mas[1000];
unsigned char count=0;
static void ISR_TC2(void)
unsigned int uiSR = AT91C_BASE_TC2->TC_SR;
if( (uiSR & AT91C_TC_COVFS) )
over++;
if( (uiSR & AT91C_TC_LDRAS) )
mas[count] = AT91C_BASE_TC2->TC_RA;
count++;
over=0;
void InitTC()
//AIC configure.
AT91C_BASE_AIC->AIC_IDCR = 1 << AT91C_ID_TC2; // Disable the interrupt first
AT91C_BASE_AIC->AIC_SMR[AT91C_ID_TC2] = 0;
AT91C_BASE_AIC->AIC_SVR[AT91C_ID_TC2] = (unsigned int) ISR_TC2;
AT91C_BASE_AIC->AIC_ICCR = 1 << AT91C_ID_TC2; // Clear interrupt
AT91C_BASE_AIC->AIC_IECR = 1 << AT91C_ID_TC2; // Enables interrupts
// Enable PWMC peripheral clock
AT91C_BASE_PMC->PMC_PCER = 1 << AT91C_ID_TC2;
// Disable TC clock
AT91C_BASE_TC2->TC_CCR = AT91C_TC_CLKDIS;
// Disable interrupts
AT91C_BASE_TC2->TC_IDR = 0xFFFFFFFF;
// Clear status register
// Set mode
AT91C_BASE_TC2->TC_CMR = AT91C_TC_CLKS_TIMER_DIV1_CLOCK | // MCK/2
AT91C_TC_BURST_NONE |
AT91C_TC_EEVTEDG_RISING |//AT91C_TC_EEVTEDG_BOTH |
AT91C_TC_ABETRG |
AT91C_TC_LDRA_RISING;//AT91C_TC_LDRA_BOTH; // each edge of TIOA
// Enable interrpt
AT91C_BASE_TC2->TC_IER = AT91C_TC_COVFS | // Counter Overflow
AT91C_TC_LDRAS; // RA Loading
// Start TC2
AT91C_BASE_TC2->TC_CCR = AT91C_TC_CLKEN | AT91C_TC_SWTRG;
// connect to PIO for TIOA2
AT91C_BASE_PIOA->PIO_BSR= AT91C_PA26_TIOA2;
AT91C_BASE_PIOA->PIO_PDR = AT91C_PA26_TIOA2;
over++;
count++;
over=0;
void InitTC()
//AIC configure.
// Disable TC clock
// Set mode
AT91C_TC_ABETRG |
// Enable interrpt
// Start TC2
Как и что, мне настроить, чтоб измерять точно время импульсов???
На АВР просто - какой кварц такая и частота, а на АРМ ПЛЛ с какой точностью умножает и делит?
Можно таймер тактировать от кварца? (бес умножений и делений)
