P.S. Ревизия процессора CU-ES2 (не инженерный образец, errat'ы нет).
INFO : Low Level Init : OK
INFO : DDRam init : OK
Init Nand flash
Load CE-BOOT from Flash to DDRAM
D_DirectRead lasted 5 ms for 0x62 bytes (timer granularity is 400)
WARNING : LoadEBootCFG: No valid Eboot configuration found.
INFO : Loading default bootloader settings
Press [ENTER] to download now or [SPACE] to cancel.
Initiating image download in 0 seconds
System ready!
Preparing for download...
INFO: Trying to initialize the internal NIC (EMACB)...
pEmac->EMAC_SA1L= 4090202
pEmac->EMAC_SA1H= 505
Init Emac Ethernet controler
Enter in AT91F_EmacEntry base = 0xbffbc000
EMACB revision 0x1010c
->Enter in AT91F_EMACInit
Found Phy (DM9161A) at address 0
CONTROL REG : 0x3100
STATUS REG : 0x7849
Autonegociation failed
ERROR: Failed to initialize EMACB Ethernet controller.
WARNING : No Ethernet link detected... Check the connection !
INFO : Retrying in few seconds. (press <SPACE> or <ENTER> to cancel)
Init Nand flash
System ready!
STATUS REG : 0x7849
