Вот еще у немцев на
сайте нашел:
Flash/NAND-Layout:<6>[ 2.165000] NAND device: Manufacturer ID: 0xad, Chip ID: 0xd5 (Hynix NAND 2GiB 3,3V 8-bit)
<6>[ 2.170000] Scanning device for bad blocks
<5>[ 2.380000] Creating 9 MTD partitions on "NAND 2GiB 3,3V 8-bit":
<5>[ 2.385000] 0x000001a00000-0x000002000000 : "kernel"
<5>[ 2.390000] 0x000001800000-0x000001a00000 : "ramdisk"
<5>[ 2.400000] 0x000000500000-0x000000700000 : "recovery"
<5>[ 2.405000] 0x000012800000-0x00001e800000 : "system"
<5>[ 2.415000] 0x00001e800000-0x00005c000000 : "userdata"
<5>[ 2.420000] 0x00005c000000-0x000060000000 : "cache"
<5>[ 2.430000] 0x000060000000-0x00007ff00000 : "local"
<5>[ 2.435000] 0x00007ff00000-0x000080000000 : "panic"
<5>[ 2.445000] 0x000002800000-0x00000a800000 : "resv"
dmesg <5>[ 0.000000] Linux version 2.6.32.9 (hzhao@emma) (gcc version 4.4.0 (GCC) ) #1 Wed Nov 3 17:55:14 CST 2010
<4>[ 0.000000] CPU: ARMv6-compatible processor [4117b365] revision 5 (ARMv6TEJ), cr=00c5387f
<4>[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
<4>[ 0.000000] Machine: WOODY
<4>[ 0.000000] Ignoring unrecognised tag 0x00000000
<4>[ 0.000000] Ignoring unrecognised tag 0x54410008
<4>[ 0.000000] Memory policy: ECC disabled, Data cache writeback
<7>[ 0.000000] On node 0 totalpages: 65536
<7>[ 0.000000] free_area_init_node: node 0, pgdat c052c54c, node_mem_map c05f4000
<7>[ 0.000000] Normal zone: 512 pages used for memmap
<7>[ 0.000000] Normal zone: 0 pages reserved
<7>[ 0.000000] Normal zone: 65024 pages, LIFO batch:15
<4>[ 0.000000] CPU IMAPX200 (id 0x13ab2000)
<6>[ 0.000000] IMAP Clocks, © 2009 Infotm Micro Electronics
<6>[ 0.000000] iMAPx200: 67108864 bytes SDRAM reserved for memalloc at 0x4107f000
<4>[ 0.000000] IMAP Power Management, Copyright 2010 Infotm
<4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping off. Total pages: 65024
<5>[ 0.000000] Kernel command line: console=ttySAC3,115200 androidboot.mode=normal bmagic=0xdb6db610
<6>[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
<6>[ 0.000000] Memory: 256MB = 256MB total
<5>[ 0.000000] Memory: 187520KB available (4480K code, 989K data, 456K init, 0K highmem)
<6>[ 0.000000] SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
<6>[ 0.000000] Hierarchical RCU implementation.
<6>[ 0.000000] NR_IRQS:128
<4>[ 0.000000] Console: colour dummy device 80x30
<7>[ 0.000000] FOUND calc 114583, divisor 36
<6>[ 0.000000] console [ttySAC3] enabled
<6>[ 0.010000] Calibrating delay loop... 791.34 BogoMIPS (lpj=1978368)
<4>[ 0.120000] Mount-cache hash table entries: 512
<6>[ 0.125000] CPU: Testing write buffer coherency: ok
<6>[ 0.135000] NET: Registered protocol family 16
<4>[ 0.155000] imapx200: Initialising architecture
<6>[ 0.160000] leaving imap_arch_init
<6>[ 0.165000] imapx200_dma_init: Registering DMA channels: ok!
<4>[ 0.205000] bio: create slab at 0
<5>[ 0.215000] SCSI subsystem initialized
<6>[ 0.220000] usbcore: registered new interface driver usbfs
<6>[ 0.225000] usbcore: registered new interface driver hub
<6>[ 0.230000] usbcore: registered new device driver usb
<6>[ 0.235000] <6>imapx200_iic0 imapx200_iic0: i2c-1: IMAPX200 I2C adapter
<6>[ 0.245000] <6>imapx200_iic1 imapx200_iic1: i2c-2: IMAPX200 I2C adapter
<6>[ 0.255000] cfg80211: Calling CRDA to update world regulatory domain
<6>[ 0.265000] NET: Registered protocol family 2
<6>[ 0.270000] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
<6>[ 0.275000] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
<6>[ 0.280000] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
<6>[ 0.285000] TCP: Hash tables configured (established 8192 bind 8192)
<6>[ 0.290000] TCP reno registered
<6>[ 0.295000] NET: Registered protocol family 1
<6>[ 0.300000] RPC: Registered udp transport module.
<6>[ 0.305000] RPC: Registered tcp transport module.
<6>[ 0.310000] RPC: Registered tcp NFSv4.1 backchannel transport module.
<6>[ 0.315000] Trying to unpack rootfs image as initramfs...
<6>[ 0.415000] Freeing initrd memory: 504K
<3>[ 0.420000] iMAP PWM Driver Init.
<6>[ 0.430000] ashmem: initialized
<6>[ 0.460000] ROMFS MTD © 2007 Red Hat, Inc.
<4>[ 0.465000] yaffs Nov 3 2010 17:54:48 Installing.
<6>[ 0.470000] alg: No test for stdrng (krng)
<6>[ 0.475000] io scheduler noop registered
<6>[ 0.480000] io scheduler anticipatory registered
<6>[ 0.485000] io scheduler deadline registered
<6>[ 0.490000] io scheduler cfq registered (default)
<7>[ 0.495000] imapbl_write_intensity: intensity 255
<6>[ 0.495000] Imap Framebuffer Driver Initialization Start!
<6>[ 0.500000] Set Lcd Backlight Brightness 0
<6>[ 0.505000] LCD TYPE :: will be initialized
<4>[ 0.515000] Console: switching to colour frame buffer device 128x37
<6>[ 0.535000] fb0: imapfb frame buffer device
<6>[ 0.550000] fb1: imapfb frame buffer device
<6>[ 0.550000] Set Lcd Backlight Brightness 75
<1>[ 0.555000] imap-fb, 0x1, 0x1, 0x3e
<6>[ 0.560000] Imap Framebuffer Driver Initialization OK!
<6>[ 0.565000] HDMI Probe to add i2c driver for HDMI device
<6>[ 0.570000] Device for HDMI will be Initializad
<4>[ 0.575000] TPI Firmware Version 0.28
<4>[ 0.990000] 0x9022
<4>[ 1.460000] 0x9022
<6>[ 1.530000] <3>imapx200_iic1 imapx200_iic1: [IMAPX200_IIC: ERR] iic thread TX_ABORT occur
<6>[ 1.530000] <3>imapx200_iic1 imapx200_iic1: [IMAPX200_IIC: ERR] TX_ABORT source is 8
<6>[ 1.530000] <3>imapx200_iic1 imapx200_iic1: [IMAPX200_IIC: ERR] slave address is 39
<6>[ 1.540000] Init HDMI device OK
<6>[ 1.540000] HDMI device add i2c driver OK!
<6>[ 2.095000] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
<6>[ 2.105000] imapx200-uart.0: imapx200_serial0 at MMIO 0x20e20000 (irq = 51) is a IMAPX200
<6>[ 2.110000] imapx200-uart.1: imapx200_serial1 at MMIO 0x20e21000 (irq = 23) is a IMAPX200
<6>[ 2.115000] imapx200-uart.2: imapx200_serial2 at MMIO 0x20e22000 (irq = 13) is a IMAPX200
<6>[ 2.120000] imapx200-uart.3: imapx200_serial3 at MMIO 0x20e23000 (irq = 33) is a IMAPX200
<6>[ 2.140000] brd: module loaded
<6>[ 2.150000] loop: module loaded
<6>[ 2.155000] iMAPx200 NAND MTD Driver © 2009,2014 InfoTM
<6>[ 2.160000] Method: IRQ(1), DMA(1), SECC(0), DEC.RDY, CRCD++
<4>[ 2.450000] [drivers/spi/spi_imapx200.c]:imapx200_spi_init!
<4>[ 2.455000] [drivers/spi/spi_imapx200.c]:imapx200_spi_probe!
<6>[ 2.460000] imapx200_ssim0 imapx200_ssim0.0: bitbang at c8b876c0
<4>[ 2.465000] [drivers/spi/spi_imapx200.c]:imapx200_spi_initialsetup!
<6>[ 2.470000] gmac-univ Ethernet Driver, V1.0
<0>[ 2.475000] eth0: gmac-univ at d0838000 IRQ 32 MAC: 00:1b:21:cb:b4:f4
<6>[ 2.480000] PPP generic driver version 2.4.2
<6>[ 2.485000] PPP Deflate Compression module registered
<6>[ 2.490000] PPP BSD Compression module registered
<6>[ 2.495000] PPP MPPE Compression module registered
<6>[ 2.500000] NET: Registered protocol family 24
<5>[ 2.505000] usbmon: debugfs is not available
<6>[ 2.510000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
<6>[ 2.520000] imapx200_usbhost20 imapx200_usbhost20: Infotm Ehci Controller
<6>[ 2.525000] imapx200_usbhost20 imapx200_usbhost20: new USB bus registered, assigned bus number 1
<6>[ 2.555000] imapx200_usbhost20 imapx200_usbhost20: irq 44, io mem 0x20c81000
<6>[ 2.570000] imapx200_usbhost20 imapx200_usbhost20: USB 2.0 started, EHCI 1.00
<6>[ 2.575000] usb usb1: configuration #1 chosen from 1 choice
<6>[ 2.580000] hub 1-0:1.0: USB hub found
<6>[ 2.585000] hub 1-0:1.0: 4 ports detected
<6>[ 2.590000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
<6>[ 2.600000] imapx200_usbhost11 imapx200_usbhost11: Infotm Ohci Controller
<6>[ 2.605000] imapx200_usbhost11 imapx200_usbhost11: new USB bus registered, assigned bus number 2
<6>[ 2.610000] imapx200_usbhost11 imapx200_usbhost11: irq 26, io mem 0x20c80000
<6>[ 2.675000] usb usb2: configuration #1 chosen from 1 choice
<6>[ 2.680000] hub 2-0:1.0: USB hub found
<6>[ 2.680000] hub 2-0:1.0: 4 ports detected
<6>[ 2.690000] usbcore: registered new interface driver cdc_wdm
<6>[ 2.695000] Initializing USB Mass Storage driver...
<6>[ 2.700000] usbcore: registered new interface driver usb-storage
<6>[ 2.705000] USB Mass Storage support registered.
<6>[ 2.710000] usbcore: registered new interface driver usbserial
<6>[ 2.715000] usbserial: USB Serial Driver core
<3>[ 2.720000] create option mode sys succeed
<6>[ 2.725000] USB Serial support registered for GSM modem (1-port)
<6>[ 2.730000] usbcore: registered new interface driver option
<6>[ 2.735000] option: v0.7.2:USB Driver for GSM modems
<6>[ 2.745000] mice: PS/2 mouse device common for all mice
<6>[ 2.750000] ---Headphone is not alive!
<6>[ 2.755000] input: gpio-keys as /devices/platform/gpio-keys/input/input0
<6>[ 2.760000] ads7846 spi0.0: touchscreen, irq 1
<6>[ 2.765000] input: ADS7846 Touchscreen as /devices/platform/imapx200_ssim0.0/spi0.0/input/input1
<6>[ 2.775000] iMAPx200 RTC, © 2009, 2014 InfoTM Microelctronics Co., Ltd
<6>[ 2.785000] using rtc device, imap, for alarms
<6>[ 2.790000] imapx200_rtc imapx200_rtc: rtc core: registered imap as rtc0
<6>[ 2.795000] i2c /dev entries driver
<6>[ 2.800000] Linux video capture interface: v2.00
<6>[ 2.805000] usbcore: registered new interface driver uvcvideo
<6>[ 2.810000] USB Video Class driver (v0.1.0)
<4>[ 3.015000] [camif]-:flag_phy_addr = 4801d000
<6>[ 3.025000] [SDHCI0]:infoTM sdhci host driver init.
<3>[ 3.030000] [sdhci]-SDIO MAX CLOCK RATE = 86400000
<6>[ 3.035000] Registered led device: mmc0::
<6>[ 3.040000] mmc0: SDHCI controller on info_sdi0 [imapx200_sdi0.0] using ADMA
<6>[ 3.045000] [SDHCI1]:infoTM sdhci host driver init.
<6>[ 3.050000] channel 1 doesn't work right now
<3>[ 3.055000] [sdhci]-SDIO MAX CLOCK RATE = 86400000
<6>[ 3.060000] Registered led device: mmc1::
<6>[ 3.065000] mmc1: SDHCI controller on info_sdi1 [imapx200_sdi1.1] using ADMA
<4>[ 3.070000] wifi_switch module init
<4>[ 3.070000] switch_gpio is 47
<6>[ 3.100000] usbcore: registered new interface driver usbhid
<6>[ 3.105000] usbhid: v2.6:USB HID core driver
<6>[ 3.115000] logger: created 64K log 'log_main'
<6>[ 3.120000] logger: created 256K log 'log_events'
<6>[ 3.125000] logger: created 64K log 'log_radio'
<6>[ 3.135000] logger: created 64K log 'log_system'
<6>[ 3.145000] IX210 iDSP driver © 2009, 2014 InfoTM
<6>[ 3.150000] IX210 iGPS driver © 2009, 2014 InfoTM
<6>[ 3.155000] Advanced Linux Sound Architecture Driver Version 1.0.21.
<6>[ 3.165000] mmc0: new high speed SDHC card at address e624
<7>[ 3.170000] ********** iis_clock_rate is 19bfcc00
<6>[ 3.170000] es8328: Audio Codec Driver v0.12
<6>[ 3.175000] asoc: es8328 <-> imapx200-i2s mapping ok
<6>[ 3.180000] mmcblk0: mmc0:e624 SU16G 14.8 GiB
<6>[ 3.185000] mmcblk0: p1
<6>[ 3.505000] ALSA device list:
<6>[ 3.510000] #0: imapx200 (es8328)
<6>[ 3.515000] TCP cubic registered
<6>[ 3.515000] NET: Registered protocol family 17
<6>[ 3.520000] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
<6>[ 3.530000] imapx200_rtc imapx200_rtc: setting system clock to 2010-11-27 10:03:27 UTC (1290852207)
<6>[ 3.560000] Bosch Sensortec Device detected!
<6>[ 3.560000] BMA150/SMB380 registered I2C driver!
<6>[ 3.565000] bma150 device create ok
<6>[ 3.610000] Freeing init memory: 456K
<7>[ 3.610000] FOUND calc 114583, divisor 36
<7>[ 4.210000] FOUND calc 114583, divisor 36
<6>[ 4.265000] yaffs: dev is 32505859 name is "mtdblock3"
<6>[ 4.270000] yaffs: passed flags ""
<4>[ 4.275000] yaffs: Attempting MTD mount on 31.3, "mtdblock3"
<4>[ 4.305000] yaffs: restored from checkpoint
<4>[ 4.310000] yaffs_read_super: isCheckpointed 1
<6>[ 4.330000] yaffs: dev is 32505860 name is "mtdblock4"
<6>[ 4.335000] yaffs: passed flags ""
<4>[ 4.335000] yaffs: Attempting MTD mount on 31.4, "mtdblock4"
<4>[ 4.370000] yaffs: restored from checkpoint
<4>[ 4.380000] yaffs_read_super: isCheckpointed 0
<6>[ 4.395000] yaffs: dev is 32505861 name is "mtdblock5"
<6>[ 4.400000] yaffs: passed flags ""
<4>[ 4.405000] yaffs: Attempting MTD mount on 31.5, "mtdblock5"
<4>[ 4.410000] yaffs: restored from checkpoint
<4>[ 4.415000] yaffs_read_super: isCheckpointed 1
<6>[ 4.430000] yaffs: dev is 32505862 name is "mtdblock6"
<6>[ 4.435000] yaffs: passed flags ""
<4>[ 4.435000] yaffs: Attempting MTD mount on 31.6, "mtdblock6"
<4>[ 4.445000] yaffs: restored from checkpoint
<4>[ 4.450000] yaffs_read_super: isCheckpointed 1
<7>[ 4.535000] FOUND calc 114583, divisor 36
<3>[ 4.580000] init: cannot find '/system/bin/playmp3', disabling 'bootsound'
<3>[ 4.600000] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
<6>[ 4.700000] warning: `adbd' uses 32-bit capabilities (legacy support in use)
<6>[ 4.790000] eth0: link down
<7>[ 4.810000] [OPS DEBUG] Get into asysops device driver
<7>[ 4.810000] [OPS DEBUG] Open asysops device node OK
<7>[ 4.810000] [OPS DEBUG] Get asysops ioctl
<7>[ 4.810000] [OPS DEBUG] ASYSOPS_CMD_GET_SHMEM
<7>[ 4.810000] [OPS DEBUG] Normal exit asysops ioctl, 0
<6>[ 5.210000] galcore galcore: GPU(v2.5.3) power is ready.
<7>[ 6.020000] charging status changed, charging_status is 1, charging_old_status is 0
<7>[ 6.895000] i2s clkdiv = 305, cdclkdiv = 24
<7>[ 6.905000] ----src_addr0 is 48a60000, src_addr1 is 48a61000
<6>[ 33.080000] request_suspend_state: wakeup (3->0) at 33084024002 (2010-11-27 10:03:57.049088000 UTC)
<7>[ 33.095000] imapbl_write_intensity: intensity 204
<6>[ 33.095000] BRIGHT SET OK
<7>[ 34.020000] battery is changing, battery is 59, old_battery is 59
<4>[ 34.610000] rtusb init --->
<6>[ 34.615000] usbcore: registered new interface driver rt2870
<6>[ 34.840000] usb 1-1: new high speed USB device using imapx200_usbhost20 and address 2
<6>[ 34.990000] usb 1-1: configuration #1 chosen from 1 choice
<4>[ 34.995000]
<4>[ 34.995000]
<4>[ 34.995000] === pAd = d5b02000, size = 476392 ===
<4>[ 34.995000]
<4>[ 35.000000] <-- RTMPAllocAdapterBlock, Status=0
<4>[ 35.755000] <-- RTMPAllocTxRxRingMemory, Status=0
<4>[ 35.765000] -->RTUSBVenderReset
<4>[ 35.765000] <--RTUSBVenderReset
<4>[ 36.065000] Key1Str is Invalid key length(0) or Type(0)
<4>[ 36.070000] Key2Str is Invalid key length(0) or Type(0)
<4>[ 36.075000] Key3Str is Invalid key length(0) or Type(0)
<4>[ 36.080000] Key4Str is Invalid key length(0) or Type(0)
<4>[ 36.085000] 1. Phy Mode = 0
<4>[ 36.085000] 2. Phy Mode = 0
<4>[ 36.090000] NVM is Efuse and its size =2d[2d0-2fc]
<4>[ 36.165000] 3. Phy Mode = 0
<4>[ 36.275000] RTMPSetPhyMode: channel is out of range, use first channel=1
<4>[ 36.295000] <==== rt28xx_init, Status=0
<4>[ 36.300000] 0x1300 = 00073200
<7>[ 38.020000] battery is changing, battery is 60, old_battery is 60
<4>[ 41.825000] ===>rt_ioctl_giwscan. 1(1) BSS returned, data->length = 191
<4>[ 41.865000] ==>rt_ioctl_siwfreq::SIOCSIWFREQ[cmd=0x8b04] (Channel=1)
<3>[ 43.455000] init: sys_prop: permission denied uid:10010 name:sys.settings_google_version
<3>[ 44.205000] init: sys_prop: permission denied uid:10010 name:sys.settings_google_version
<3>[ 44.555000] init: sys_prop: permission denied uid:10010 name:sys.settings_google_version
<3>[ 44.880000] init: sys_prop: permission denied uid:10010 name:sys.settings_google_version
<3>[ 45.065000] init: sys_prop: permission denied uid:10010 name:sys.settings_google_version
<3>[ 45.225000] init: sys_prop: permission denied uid:10010 name:sys.settings_google_version
<7>[ 48.900000] i2s clkdiv = 305, cdclkdiv = 24
<7>[ 48.995000] ----src_addr0 is 48a60000, src_addr1 is 48a61000
<7>[ 48.995000] trigger command is 1
<7>[ 49.685000] trigger command is 0
<7>[ 51.440000] [OPS DEBUG] Get into asysops device driver
<7>[ 51.440000] [OPS DEBUG] Open asysops device node OK
<7>[ 51.440000] [OPS DEBUG] Get asysops ioctl
<7>[ 51.440000] [OPS DEBUG] ASYSOPS_CMD_GET_SHMEM
<7>[ 51.440000] [OPS DEBUG] Normal exit asysops ioctl, 0
<7>[ 53.435000] [OPS DEBUG] Get into asysops device driver
<7>[ 53.435000] [OPS DEBUG] Open asysops device node OK
<7>[ 53.435000] [OPS DEBUG] Get asysops ioctl
<7>[ 53.435000] [OPS DEBUG] ASYSOPS_CMD_GET_SHMEM
<7>[ 53.435000] [OPS DEBUG] Normal exit asysops ioctl, 724249387
<7>[ 53.440000] [OPS DEBUG] Get into asysops device driver
<7>[ 53.440000] [OPS DEBUG] Open asysops device node OK
<7>[ 53.440000] [OPS DEBUG] Get asysops ioctl
<7>[ 53.440000] [OPS DEBUG] ASYSOPS_CMD_GET_SHMEM
<7>[ 53.440000] [OPS DEBUG] Normal exit asysops ioctl, 724249387
<7>[ 60.200000] i2s clkdiv = 305, cdclkdiv = 24
<7>[ 60.245000] ----src_addr0 is 48a60000, src_addr1 is 48a61000
<7>[ 60.245000] trigger command is 1
<7>[ 60.935000] trigger command is 0
<7>[ 192.020000] battery is roll-back, battery is 73, old_battery is 60
/proc/cpuinfo
Processor : ARMv6-compatible processor rev 5 (v6l)
BogoMIPS : 791.34
Features : swp half thumb fastmult vfp edsp java
CPU implementer : 0x41
CPU architecture: 6TEJ
CPU variant : 0x1
CPU part : 0xb36
CPU revision : 5
Hardware : WOODY
Revision : 0004
Serial : 0000000000000000
/proc/meminfo
MemTotal: 188700 kB
MemFree: 2828 kB
Buffers: 44 kB
Cached: 25128 kB
SwapCached: 0 kB
Active: 65624 kB
Inactive: 65056 kB
Active(anon): 55308 kB
Inactive(anon): 60400 kB
Active(file): 10316 kB
Inactive(file): 4656 kB
Unevictable: 284 kB
Mlocked: 0 kB
HighTotal: 0 kB
HighFree: 0 kB
LowTotal: 188700 kB
LowFree: 2828 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Dirty: 4 kB
Writeback: 0 kB
AnonPages: 103400 kB
Mapped: 21208 kB
Shmem: 9916 kB
Slab: 5080 kB
SReclaimable: 1024 kB
SUnreclaim: 4056 kB
KernelStack: 1984 kB
PageTables: 6296 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 94348 kB
Committed_AS: 3059576 kB
VmallocTotal: 514048 kB
VmallocUsed: 108420 kB
VmallocChunk: 353284 kB
Программа прошивки аскетична :
Нажмите для просмотра прикрепленного файлаНе один из пунктов меню не действует.
