Цитата(v-vovchek @ Jun 9 2011, 23:21)
Легкий ответ, но мне с ним не легче. Уже пробовал искать на сайте у Altium, но не смог найти.
Видать где-то далеко запрятали!
System Requirements
Ensure that your computer meets the system requirements listed below, prior to installing the Altium Designer software.
Recommended System Requirements
Windows 7 (32-bit or 64-bit) ~
Intel® Core™2 Duo/Quad 2.66GHz (or faster) processor or equivalent
4 GByte RAM
10 GByte hard disk space (Install + User Files)
Dual monitors with at least 1680x1050 (widescreen) or 1600x1200 (4:3) screen resolution
NVIDIA® GeForce® 8000 # series, 256MB (or more) graphics card * or equivalent
USB2.0 port (if connecting to a NanoBoard-NB2 or NanoBoard-3000)
DVD-Drive
Adobe® Reader® 8 (or above)
Internet Connection
Microsoft Excel (required for Bill of Materials templates)
Minimum System Requirements
Windows XP Professional SP2 (or later) $
Intel® Pentium™ 1.8GHz processor or equivalent
2 GByte RAM
3.5 GByte hard disk space (Install + User Files)
Main monitor 1280x1024 screen resolution
Strongly recommended: second monitor with minimum 1024x768 screen resolution
NVIDIA® GeForce® 6000/7000 series, 128MB graphics card * or equivalent
USB2.0 port (if connecting to a Nanoboard-NB2 or NanoBoard-3000)
DVD-Drive
Internet Connection
~ Testing also performed on Windows Vista and Windows XP for the recommended system requirements.
$ Testing also performed on Windows Vista and Windows 7 (32-bit and 64-bit) for the minimum system requirements.
# Graphics for the recommended system tested using an 8500 GT (256MB).
* To take advantage of the accelerated graphics engine, including 3D visualization, your graphics card must support DirectX 9.0c and Shader model 3.
Performance comparison of graphics cards
Graphics cards are a critical hardware element that can have a large impact on both the performance and stability of systems. These benchmarks help you choose the right 3D PCB graphics engine for your needs and budget. Choose the right hardware requirements necessary to achieve stunning results, make the whole system more responsive and ‘feel’ better, and remove distractions to design caused by lags in the GUI. Altium Designer’s PCB and schematic editors have been optimized for use with DirectX 9.0c. As such, “workstation” graphics cards which do not have native DirectX 9.0c (or later) acceleration in hardware will have inferior performance, when compared to the same generation of “gaming” graphics cards. We therefore strongly recommend the use of gaming cards instead of workstation cards.
Installations required for FPGA design
Implementing an FPGA design in a device requires the installation of third-party software tools. These tools are available as downloads from FPGA vendor websites. A list of the vendor tools and devices supported by Altium Designer and links to the appropriate websites are provided in the Community section.
