К сожалению обзавестись лицензией последней версии у меня сейчас возможности нет, поэтому попытаю счастье просто задав вопрос
Суть проблемы вот в чем:
составил схему для моделирования, запустил и вот что вышло:
**** 01/01/02 03:19:48 ********* PSpice 9.2 (Mar 2000) ******** ID# 1 ********
** Profile: "proto2-proto2" [ E:\TEST\lab3-proto2-proto2.sim ]
**** CIRCUIT DESCRIPTION
** Creating circuit file "lab3-proto2-proto2.sim.cir"
** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
*Libraries:
* Local Libraries :
.LIB ".\lab3.lib"
* From [PSPICE NETLIST] section of C:\Program Files\Orcad\PSpice\PSpice.ini file:
.lib "C:\Program Files\Orcad\Capture\Library\PSpice\IXYS.lib"
.lib "C:\Program Files\Orcad\Capture\Library\PSpice\IXFK120N20.lib"
.lib "C:\Program Files\Orcad\Capture\Library\PSpice\ixdd415si.lib"
.lib "C:\Program Files\Orcad\Capture\Library\PSpice\blf242.lib"
.lib "E:\TEST\lab3.lib"
.lib "E:\TEST\LAB2.lib"
.lib "E:\TEST\LAB1.lib"
.lib "nom.lib"
*Analysis directives:
.DC LIN V_V2 0 60 0.01
.PROBE V(*) I(*) W(*) D(*) NOISE(*)
.INC ".\lab3-proto2.net"
**** INCLUDING lab3-proto2.net ****
* source LAB3
V_V1 N00267 0 5.5Vdc
V_V2 N00216 0 60Vdc
M_Q3 N00216 N00267 0 0 501N04A
**** RESUMING lab3-proto2-proto2.sim.cir ****
.END
WARNING -- Library file E:\TEST\lab3.lib has changed since index file lab3.ind was created.
WARNING -- The timestamp changed from Tue Jan 01 03:18:58 2002 to Tue Jan 01 03:19:38 2002.
Making new index file lab3.ind for library file lab3.lib
Index has 1 entries from 1 file(s).
* PSpice Model Editor - Version 9.2
*SYM=POWMOSN
.subckt 501N04A 10 20 30
* TERMINALS: D G S
* 500 Volt 4.5 Amp 1.5 ohm N-Channel Power MOSFET 10-30-2001
M1 1 2 3 3 DMOS L=1U W=1U
RON 5 6 9.5
DON 6 2 D1
ROF 5 7 3.5
DOF 2 7 D1
D1CRS 2 8 D2
D2CRS 1 8 D2
CGS 2 3 .6N
RD 4 1 1.5
DCOS 3 1 D3
RDS 1 3 5.0MEG
LS 3 30 .1N
LD 10 4 1N
LG 20 5 1N
.MODEL DMOS NMOS LEVEL=3 VTO=3.0 KP=6.0
.MODEL D1 D IS=.5F CJO=1P BV=100 M=.5 VJ=.6 TT=1N
.MODEL D2 D IS=.5F CJO=175P BV=500 M=.5 VJ=.6 TT=1N RS=10M
.MODEL D3 D IS=.5F CJO=250P BV=500 M=.3 VJ=.4 TT=400N RS=10M
.ENDS
ERROR -- Model 501N04A used by M_Q3 is undefined
Не знаю, что можно сделать, чтобы работало...
Описываю примерный порядок произведенных действий:
1) скопировал текст модели из спецификации транзистора с сайта производителя
2) создал olb библиотеку в Orcad Capture
3) создал part, отрисовал и ввел параметры (см. рис. содержание библиотеки olb.bmp)
4) создал lib библиотеку в PSpice Model Editor (см. рис. библиотека lib.lib)
5) создал новую модель, перешел в текстовое представление, удалил все и скопировал содержание модели из спецификации (см. рис. содержание библиотеки lib.bmp)
6) сохранил все, пооткрывал все файлы - убедился, что все сохранилось
7) создал проект для моделирования, вставил файлы и попытался запустить процесс, однако ошибка все испортила. Лог моделирования см. вверху, параметры моделирования см. рис. параметры моделирования.bmp.
Обращаю внимание, что все библиотеки были подключены. Также пробовал создать part для модели из lib библиотеки командой File->Create Capture Parts... Однако выдает ошибку типа: "Error - Failed to Find File [C:\...\Pspice\IXYS.err]!!!". Создание файла с таким расширением успеха не принесло.
